Questions about fuel gauge from a new prius owner
Discussion in 'Gen 2 Prius Fuel Economy' started by DRogers, Nov 7, 2014.
  1. DRogers
    DRogers Junior Member
    Ottawa Ontario
    I've owned my Prius about 8 days now, when I bought it it was on the last pip on the gauge (maybe two pips left not really sure) so I immediatly filled it the tank took $25CDN to fill (about 22L of fuel), I think to myself wow small tank. I get the car home and start to read the manual and find out wow the tank is suppoosed to hold 45L of fuel. Now I'm confused, but maybe the gauge was higher than I thought. (confused). So I drive the car all week watching the fuel milage and gauge like a hawk. This morning on my way to work 140km round trip each day the gauge drops to the last pip again (10km before I reach work). The computer says I've averaged 4.6L per 100km (62.77mpg) not bad. with a total milage on this tank of 600km. (math side of this) 600km @ 4.6L per 100, 6X4.6=27.6L. So the gas I've burned is approx what I thought I put in the tank.
    Now this will all be approximates but here goes, I understand that the gauge in the prius is not known for it accuracy and that Toyota has made a few liters of fuel non useable for cooling and such, so if the tank holds according to book 45L, 5L of it being not useable(approx) that leaves 40L of useable fuel, now if the bladder type tank varies the amount of fuel you can put in a fill up due to temperature and I have used 27.6L of the tank, that should leave me between 10 and 13L of unused fuel still in the tank that my gauge isn't showing. This leaves a few possibilities,
    1- my gauge is way out of cal.
    2- I have the smallest tank installed in any prius on the planet (I doubt this one) or
    3- the previous owner used the car to smuggle crack and once I open the tank I'll be rich.
    I do not want to run the car out of gas but, I really need to figure this one out. If I understand the system correctly the last pip will begin to flash once I reach the as per say reserve fuel, giving me approx 50km till I'm really out of gas (last pip not flashing yet), so should I push the tank and see if I can get another 300km (approx) out of it telling me the gauge is really out of cal or not, or if I run it out of gas before that than I'll fill it to see how much it holds.
    (side note) 600Km on a tank seems very low compared to numbersI'm seeing by other members on this site, but I have no personal experience.
    Any comments/suggestions would and will be of great appreciation.
  2. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    What temperature is Ottawa now?
    The North American Gen 2 Prius has a flexible bladder in the steel tank. How flexible it is depends on outside air temperature.
    In Mississippi, in the summer, in late afternoon I could get 11 gallons in my Gen 2, in winter in the morning, 7 gallons. Your winters will be colder than mine.
    51,099
    see threads on how to fill your gen II gas tank. it can be tricky.
  4. DRogers
    Ottawa Ontario
    I don't think its a way to fill the tank thing as that might explain few litters but I can't beleive it would affect around half the capacity of the tank but I will look into how to fill your genII gas tank.
    Temp in Ottawa when I filled was around 50'F temp today 35'F, so your telling me there is a 4 gallon difference in Mississippi between summer and winter???
    Because if thats the case I would be very interested in what the temperature shift is for you as here in Ottawa summer temps are around 80'F winter tems are around -30F making it about a 110'F temp swing so in the winter I should get around 2 gallons in it.
    #4 DRogers, Nov 7, 2014
  5. tanglefoot
    tanglefoot Whee!
    625
    188
    Colorado
    A good strategy to get more fuel into the tank/bladder is to fill at a slower rate (first click on the pump handle). That way the bladder can better expand to accommodate the fuel.
    Your numbers sound pretty normal. I usually fill 7-8 gallons and I believe tank capacity is about 11 gallons. It does change depending on temperature but not THAT much. A cold, Colorado winter fill-up usually results in 6-7 gallons going in.
    It's good practice to line up a gas station when you reach two pips on the gauge. Running out can cause damage, and with the variability of the gauge reading, you don't want to cut it close.
  6. JimboPalmer
    12,470
    6,876
    Greenwood MS USA
    Summer afternoon 108 F 42 C, winter morning 18 F -8 C in MS.
  7. dorunron
    dorunron Senior Member
    3,318
    1,105
    Houston, TX
    D Rogers,
    Welcome to Prius Chat.
    The Gen II Prius is blessed and cursed with that bladder.
    Best advice from a former Gen II driver. Fill up at 2 pips. Don't try to figure it out. You will drive yourself crazy doing so. Just fill up at 2 pips. Also if you want a good fill up, allow the system to breathe a little bit BEFORE you add the fuel. By breathing, I mean to loosen cap halfway and let the whole thing vent for at least a minute.
    Now when adding the fuel, fill as slow as possible. When the handle clicks off, hang up the pump and drive off. Don't top off the tank either.
    If you will do the above, you will have no worries.
    Again, trust me on this one.
    Best of luck to you,
    Ron (dorunron)
  8. DRogers
    Ottawa Ontario
    I think I understand a little better how the system and blader work. I will fill up at 2 pips makes sense to me. I did try and push it on my way home that night and I didn't make it home without gassing up, but I know that the blinking pip and the audible chime when the blinking starts all work. once the blinking started I found the closest gas station I could find off highway 416, in turned out at that time to be about 18 km after the blinking started, I was a little worried I won't make it but I did. It took 27L of fuel to fill again, temperature was around 10'C (52'F) I never was one of those that wanted to see how far I could go on a tank of gas I just like to have an idea in case I'm ever in a situation that I have to push the car, I like to know how far I can push it, if and only if I have no other choice.
    Thank you eveyone for your input it was appreciated and needed.
