Questions about my 2007 Prius!
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by darkgiant, Aug 16, 2015.
  1. darkgiant
    darkgiant Member
    287
    42
    Seattle
    Hi All,
    I have noticed the past months (maybe for a while, probably picked it up just a few weeks ago) when I accelerate, I hear this grinding noise, but once I let go of the gas pedal, and slowly get back on it, the grinding noise goes away. To give a better example, when I step on the gas as I normally do, this grinding noise (it is coming from the front, I feel like it is coming from the passenger side, can't confirm 100%) but once I let go of the gas pedal, it goes away. The noise itself starts when I start picking up speed from a full stop, so when I am going at around 0-30 MPH I hear the noise, after that, I honestly can't tell (road noise may be blocking it off, not sure).
    I went around the car and tires, and everything looks fine, I have no error codes thrown at me, thus, I am posting here as I really want to fix this issue as it is really bugging me. (It doesn't impact my drive, but that grinding noise is definitely not the normal sounds of a Prius).
    Also another question - I originally got a wheel alignment on this car back in April, I had to go back to my mechanic (my mechanic does Prius work, and my parents have done their regular maintenance from him for years). For some reason, my driving wheel is slightly off to the right, when I go freeway speeds, I have to keep my cars steering wheel ~5 degrees to the right so it can go straight. It definitely goes straight once I leave it at that position, could this just mean my car just needs an alignment again? I was intending on going back to the same mechanic, bu was wondering on whether or not I should instead check out the Toyota Dealership (though, seeing these forums, people seem to avoid* them).
    Anyways, appreciate any help here!
  2. exstudent
    exstudent Senior Member
    2,214
    905
    Torrance, CA
    Grinding noise could be due to dry, front disc caliper pins. When was the last the they were cleaned and properly lubricated?
    The car is being aligned with the wheel off-center. Have the alignment person go on a test drive to see what off-center looks like, so he knows he needs to drive onto the alignment rack with the steering wheel off center, to bring it back to center, after alignment.
  3. Beachbummm
    Beachbummm Senior Member
    1,160
    392
    wheel bearing is a possibility ..jack up one wheel at a time and spin them
  4. IMkenNY
    IMkenNY Im just being nosy
    477
    303
    Tropical Buffalo NY
    Four Touring
    I picked up a 2007 102,000 mile project Prius this summer with known transaxle and traction battery problems. It exhibited a noise similar to what you are describing.
    However my 2007was also throwing a HV leak code with transaxle sub codes.
    Toyota took all my project fun away and replaced the traction battery and transaxle under warranty.
    You may want to try to change the transaxle fluid or at least verify its at the proper level.
    m.wynn likes this.
  5. bisco
    51,148
    how many miles on her?
  6. bisco
    51,148
    i thought the tranny was 5/60?
  7. darkgiant
    darkgiant Member
    287
    42
    Seattle
    Yeah, there are no error codes, no hindrance in driving performance, nor MPG (I am averaging roughly 51 MPG, I have filled up around 14 times so far, since purchasing the car. I purchased the car itself back in March of this year).
    The car currently has ~152,000 miles, my commute is 30 miles one way (so a total of ~60 miles for a day).
    That being said, the only thing I had performed on the car was just a regular oil change (which was done myself) and an alignment, which was done by my mechanic. I had the mechanic inspect the car before I purchased it, and everything including the brakes were in great shape, but I guess my first start to diagnosing this "grinding' noise is from the tires, calipers?
    That being said, does this sound like a serious issue? I understand we haven't determined what the cause can be, but getting a general idea of all the possibilities, is this something can impact the driving performance of the car?
    #7 darkgiant, Aug 17, 2015
  8. IMkenNY
    477
    303
    Tropical Buffalo NY
    Four Touring
  9. bisco
    51,148
    does the noise change if you're turning while accelerating?
  10. darkgiant
    darkgiant Member
    287
    42
    Seattle
    That is a good question, to be honest, I don't notice the noise at all when turning, so I guess no?
    I muted my music today for my commute, I am very confident it is coming around the front passenger area, and it goes away after I hit ~30 MPH. The grinding noise doesn't always happen, but when I am at a full stop, and than accelerate, that is when I hear it, but again, it doesn't always happen. I am assuming this is just something rubbing/touching in that front tire?
  11. ChapmanF
    17,341
    A sound recording could help a lot.
    You're describing a sound that's present during hard acceleration. Are you familiar with what "engine knock" on acceleration sounds like? I know that may not seem plausible because you expect "knock" to mean, well, a "knock" sound, but that's just the standard term for it, and a really bad match for what it sounds like. What it really sounds like is more like small marbles in a blender ... even a kind of grinding-like sound, going away when you back off the accelerator. The engine is on the front passenger side of the car, where you describe hearing the sound.
    The engine is built with a knock sensor that's there to tell the computer when knock is happening, which the computer corrects by adjusting the spark timing. If the sensor has gone bad, that won't happen.
    If that's what it is, it's worth fixing; repeated knocking episodes will take their toll on the engine. Your service manual on techinfo.toyota.com can step you through testing and (if necessary) replacing the knock sensor (or finding out the problem is something else) ... the sensor isn't horribly buried or hard to get to.
    -Chap
  12. darkgiant
    darkgiant Member
    287
    42
    Seattle
    I will try my best to get a sound recording. I ran a Torque Test on the car just to make sure I didn't skip anything, while the car is not throwing any errors on me via the Dash, or the app, the test result just had something that came out red, attached a screenshot:
  13. valde3
    valde3 Senior Member
    2,002
    746
    Finland
    Do you think that knock sensor could be faulty without giving fault code? Gen 2 Prius uses non-resonant (traditional) type knock sensor. It has three possible fault codes. Of course none of these codes would definitely tell that the sensor itself is faulty. But could it really be that none of these codes would be set with faulty sensor?
    P0325 - Knock sensor signal level remains at low for more than 10 seconds
    P0327 - Output voltage of the knock sensor is 0.5 V or less
    P0328 - Output voltage of the knock sensor is 4.5 V or more
    This could be just resonant thing still since rpm in a Prius is tied with power demand not speed.
    To OP: Try pressing the accelerator while Prius is in PARK-gear. Can you get the same noise out of the engine? Push accelerator carefully to get the engine to correct rpm.
    #13 valde3, Aug 18, 2015
  14. darkgiant
    darkgiant Member
    287
    42
    Seattle
    I had pressed the accelerator while the car was in park, the sound was totally normal, it just sounded like a normal Prius engine revving, which wasn't pretty loud at all. The grinding noise is only heard when the tires are moving, so I am assuming this crosses out something on the list of possiblities?
    I will have a GoPro in the next couple of days, I will just try to put it as close as possible to the area where I hear the sound, and have it record my entire commute, but that is probably in the next few days. I may try to keep my phone's mic placed as close to the passanger side and have it record, not sure how effective it would be, bu worth a try.
  15. darkgiant
    darkgiant Member
    287
    42
    Seattle
    So... today, I decided to check my oil levels. I honestly can't remember when was the last time I checked it, but I thought it wouldn't be too big of an issue since I had changed the oil back in June. Anyways, the oil level is very, very low. The car didn't give me any light about low engine oil, but it was seriously low, so I poured in some oil to the appropriate level. I will drive it again tomorrow, and see if that changes anything, no idea how the oil levels go to low, I am assuming the long commutes especially on a freeway burns oil faster than I thought? There are no leaks, everything is dry underneath the car when I jacked it up.
  16. bisco
    51,148
    how much did you put in, and after how many miles since the oil change? a lot of prius burn oil at your mileage, especially when the original owners didn't maintain properly or abused it.
  17. darkgiant
    darkgiant Member
    287
    42
    Seattle
    I want to say roughly ~2,400 miles since last change? I do drive 30 miles each direction 5 days a week. Though, I usually drive slow, especially on the freeway as I try to get as many MPG's as I possibly can. The weird part is that no indication light or anything came on, so I have no clue why the car itself didn't warn me. I honestly can't say exactly how much I filled, but I used the remaining oil from the last oil change and poured that in, I want to say it is now half way full? I am definitely going to do an oil change this weekend.
    The car does average a total of ~51 - 53 MPG's per each fill-up, so no idea whats up here.
    This is kind of getting me nervous now...
  18. Patrick Wong
    18,200
    6,493
    Where was the oil level on the dipstick, before you added oil? You need to estimate how much oil you added - for example, 1/2 quart?
    If you have only driven 2,400 miles since the last oil change, why do you feel the need to change the oil now? Instead, add sufficient oil until the level is at the top dimple on the dipstick. Then see how much oil the engine consumes per 1,000 miles.
    It would really help for you to develop some facts about your engine's oil consumption, rather than get nervous.
  19. darkgiant
    darkgiant Member
    287
    42
    Seattle
    The oil level was very close to the dimple. The bottle didn't have a measurement line that told me how much oil was left in the bottle, but I can assure you that from the dipstick, it reached pretty close to the half-way of the low and high marks on the dipstick.
    My only reason for possibly changing the oil is just to keep a close monitor of the oil fluctuation this time around. I can go ahead and continue adding it, but I figure doing a change now would teach me my lesson of keeping a very close eye on the fluid levels of the car, unless it is just counterproductive doing so.
    The 2,400 mile mark is my approximation, I am currently away from the car, but I reset the Odomoter trip reading every time I change my car, I can post that once I am back with my car again.
  20. Patrick Wong
    18,200
    6,493
    I assume this was the "before" condition, and that you are referring to the lower dimple in this statement? If so, then no damage was done to the engine.
    There are a few owners who actually allow the oil level to drop off the dipstick and wonder what the low oil pressure light on the dashboard is about. Fortunately you are not a member of that group. The Prius does not have a low oil level light, only a low oil pressure light. And by the time you see that light, serious damage is being done to the engine.
    I assume this is the "current" dipstick level? The distance between the top and bottom dimples is approximately 1.6 US quarts. Hence you probably added 0.5 to 0.7 quarts of oil.
    Well, it is your business if you want to change the engine oil now, but if in fact only 2,400 miles have elapsed there is no reason to do so. Just add enough oil to bring the level to the top dipstick dimple, log that odometer reading, then see how much oil is consumed as you drive 1,000 miles beyond that reading.
    What about the grinding noise you were complaining about in your OP? What happened to that?
