Questions about my "multipoint inspection" results (picture)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by LulzChicken, Jun 19, 2011.
  1. LulzChicken
    LulzChicken Prius Enthusiast
    791
    135
    Alabama
    *scroll down for picture*
    Hey guys, I recently got my oil changed and as normal they did the 27 point inspection as they call it.
    From these results they are telling me:
    1. Engine air filter may need replacement soon
    2. Cabin air filter may need replacement soon
    3. My tire tread wear level is between green/yellow
    4. My rear breaks are worn pretty good so far
    A little information about my vehicle:
    -15K Miles
    -owned for 2 years
    -mainly city, but some highway miles.
    Does this seem right? The filters, I don't really care about. The main concern I have is the status of my rear breaks. Do his measurements look correct? I usually apply the parking break anytime I park (whether if I am on an incline or not) so, does the parking break use the rear breaks to hold the vehicle in place? If so, maybe that is why they are worn down so badly already. Also, when breaking, after the "charging" meter is filled up all the way, does the Prius switch to front or rear breaking? Because, if I remember correctly it's the front breaks. Which would mean the wear on my rear breaks doesn't make sense. Any further input here? Thanks!
    td;dr - Does the break wear look right for the mileage on the car? Even if I used the parking break a lot?
    I thought these breaks were suppose to last a lot longer than this.
    Appreciate any input!
    If the picture does not display properly, here is a link: http://i54.tinypic.com/kbbq69.jpg
  2. theloop82
    theloop82 Member
    Spanaway, Wa
    I would first advise that you never go wherever this was again. Second, get out that jack in the back of your car and take one of the back wheels off, and take a measurement. Third, I would find out what the brand new pads are supposed to be in the manual. Then I would no doubt find that the technician was lying his nice person off and i would call that number and shove it down their throat until i got something for free. Preferably all the filters you "need", and then do it yourself.
    This is the reason I do all my own maintenance.
  3. LulzChicken
    791
    135
    Alabama
    I won't be going to this dealer anymore in the near future. I'm going to be moving for college soon and there is another dealer (hopefully better) down the road. I really appreciate your advice. I'm going to go back and get my tires rotated in a couple of weeks. I don't think they do a 27 point inspection when you get a rotation done, but if they do, I can't wait till they give me different numbers this time. Thank you, theloop82, I appreciate your insight.
    If anyone else has input regarding how worn down my tires/breaks are I'd be more than welcome to hear what you have to say!
  4. macmaster05
    macmaster05 Senor Member
    4,050
    730
    Lol calm down Loop.
    Chicken, take a look at the pics I took for you. At 15,000 miles they said mine was 9 9 3 3 (RF LF RR LR). At 20,000 miles they said 8 8 5 5. I guess brake lining grows, huh? :rolleyes: No, like tire tread, these brake measurements are incredibly subjective. Your brakes are fine even the "yellow zone."
    You are correct that the rear brakes wear faster for some reason, as our numbers show. I use the E-brake too but I'm certain that has anything to do with it. There's no friction on the brake when the car isn't moving.
    BTW, try saying "rear brakes wear faster" 10 times in a row. It's not easy man! :rockon:
  5. LulzChicken
    791
    135
    Alabama
    It sure does seem that these measurements never come out how they're suppose to half of the time. It's like the dealership take a look at your mileage, and guesses how much is left. Once again, I really appreciate you taking the time to snag those pictures for me. Makes me feel better :p. Do you have an idea of when I should actually start to worry about replacing the breaks? As in, mileage? Thank you!
  6. macmaster05
    4,050
    730
  7. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    Lulz, it's easy enough to measue the linings yourself. Per the Toyota Repair manual Gen III front linings are 10mm thick and rear are 9.5mm thick when new. They are acceptable down to 1mm thick, although you probably shouldn't go below 2 mm unless you check them yourself at frequent enough intervals.
    Most people seem to get over 100k miles on a set of Prius brake linings but that can vary a lot depending on how you drive.
    Even an "honest" dealer will probably just eyeball the linings and guess at their thickness, a dirtbag dealer will report an unrealistically low number.
  8. LulzChicken
    791
    135
    Alabama
    Thanks for the link to that thread. Sure is an interesting read. I'll worry about it once my mileage gets up quite a bit more. My car is too young to get the breaks changed anytime soon in my opinion. Thanks again.
    Ahh so the rear linings are a little less thick than the front. Maybe that explains the variance. Thanks for your input. I may measure them one day, but not this soon I don't think. I can't imagine it costs too much to have them replaced either. I sure hope not anyway. Thanks for chiming in xs650!
  9. Dweezil
    Dweezil Cat Juggler
    162
    26
    St. Louis
    Wow! It's like you're psychic or something! :D
  10. chrisj428
    chrisj428 Active Member
    680
    144
    35
    Vernon Hills, IL
    It's not uncommon for rear brake pads to wear faster than fronts on a vehicle with electronic brakeforce distribution, especially when the vehicle is typically stopped in a gentle fashion.
  11. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Yeah, I would worry about your rear breaks but not your rear brakes. lol... Tom?
    Do it sometimes too.
  12. LulzChicken
    791
    135
    Alabama
    Why is this? As far as I understood - if I braked in a slow manner to where the "charge" meter was not filled up all the way I would barely be using any friction breaks at all - prolonging the life of my actual breaks. Turns out it's the opposite according to ya? At the rate these are going, I'll have to replace them at 30K or ~4 years. Which, I guess, isn't horrible - but I expected a little more after reading about everyone else's experiences.
  13. xpcman
    xpcman Senior Member
    1,302
    295
    California - SF Bay area
    This is the first time anyone has ever suggested the rear brake pads wear faster on a Prius. The Gen III was the first US Prius to have rear disk brakes. Prior to that the US got drums on the rear. While the rest of the world got disks on all 4 wheels. Many of the 2010 Gen IIIs are at 40k and above. I would assume that we would hear from any and all of the owners needing brake pads at this early date.
  14. The Critic
    The Critic Resident Critic
    3,193
    2,327
    CA
    This is true for a lot of cars, especially for a number of th newer VW and Honda cars.
    However, my experience so far with the Gen III Prius is that it has a significant front brake bias, so I would be quite surprised if the rears wore out first. For example, when I picked up my Prius last Saturday, I took it to a quiet road to bed in the pads. I made 15 stops in a row from 40 MPH, in N, to seat the pads. After this process, the front pads were smoking heavily and it was obvious that a moderate amount of material had transferred to the new rotors. On the other hand, on the rears it looked like only a light amount of material was transferred and the brakes were not nearly as hot as the fronts.
    MB860 ?
  15. xs650
    xs650 Senior Member
    4,539
    1,436
    Northern California
    I can see one situation where the rear brakes would wear faster than the fronts. But I do not know if the Prius braking system is sophisticated enough to do that.
    No pad wear: Only using regen for braking
    Fronts wear more than rears: Hard braking
    Possibly......
    A lot of braking just over the amount that regen provides. If, and that's a big word, the Prius brake system applies in the rear brakes first when you go a bit over regen brakiing.
    I would need to see more than some dealer's shop guy eyeball estimate of pad wear before I could believe that actually happened though.
  16. The Critic
    3,193
    2,327
    CA
    Sorry for changing the subject slightly, but in the 500 miles or so that I have driven my Gen III, I would guess that 2/3 of my stops feel like they were done by friction braking. I think this is confirmed by the heavier pad deposits and scoring on the front rotors. On the Gen II I drove, it felt like more regenerative braking was taking place. Does the Gen III's regenerative braking only used during very light stops?
    MB860 ?
  17. ETC(SS)
    6,958
    You need to call the number on that sticker immediately and ask them for an email address. Cut copy and paste the link for this thread to that account.
    They're crooks!!
    Tell all your friends.
    FWIW...Priuses aren't really set up for doing e-brake turns, so you'll unlikely be wearing out your rear brakes by (normally) applying the parking brake. It's like wearing out a pencil eraser by placing it into a holder blunt end down. Doesn't work that way. No rubbing. No brake wear.
    It torques me off that an allegedly good brand (Toyota) cannot police its franchisees any better than they do.
    Every time I have a GM worked on---which is like, 3 times in the last 10 years they mail me a customer satisfaction survey form about 4 weeks later.
    If Toyota does this for you...clue them in.
    Good Luck in school!!! :D
  18. LulzChicken
    791
    135
    Alabama
    I really should send them an email to this thread. Maybe it will make them think twice about how smart their customers are. My car is my pride and joy in life, and if they think that they are going to jip me, they best think again. Thanks for the input, ETC.
    For everyone else who has contributed to this thread, thank you! I'm still reading every post, but not replying to everyone individually. When I get my tires rotated, I'll see what they have to say about my breaks then.
  19. Mendel Leisk
    40,586
    Rear drum brakes are still fairly common. Rear disk brakes are kind of complicated by the inclusion of parking brake. The second gen Honda Civic Hybrid started out for 06 with rear drum brakes, then maybe 2 years later was revised to disk brakes. The 3rd gen, just coming out (sometime :rolleyes:), supposedly reverts to rear drum brakes.
    Bottom line, rear brakes do less work than front, are more suited to parking brake application, and can be lower maintenance.
  20. ChickenBP
    ChickenBP New Member
    My wife had the car at the dealership today for routine maintenance at 30K miles today and the dealership reported that car needs rear brake pads, shims, and rotors for $585 plus tax. Report stated left and right front brake pads are 8 mm, and both rears are "less than 1 mm" and uneven.
    Everything I've read says this is ridiculously early for this kind of repair. Any thoughts? If the pads are that worn, are the rotors definitely going to need to be replaced? I haven't been home to take the wheel off to check the pads myself.
