Questions About Replacing NiMH with Li-Ion Battery?
Discussion in 'Prius c Technical Discussion' started by Haider_carforce, May 4, 2020.
  1. Haider_carforce
    Haider_carforce New Member
    Pakistan
    2012 Aqua
    I am also working on replacement of NiMh with Li Ion.
    Each cell of toyota prius is 7.2v 6.5 Ah and all are connected in series to give output of 144v 6.5 Ah. The lithium ion like 18650 has a 3.7v and 2.0Ah. If we connect 2s4p configuration 8 cell of 18650 results into 7.4v 8.0Ah of a single unit which replacement for each cell of NiMh.
    What is your review about this ?
    What problems will occur?
    What problems did you face in you working?
  2. Amir Islam
    Amir Islam New Member
    Pakistan
    Three Touring
    I hope there will be no problem and better performance because of lithium Ion battery.
    I hope car will perform better because of lithium Ion battery. Kindly share the results
  3. AlphaFox
    AlphaFox New Member
    23
    East Longmeadow, MA
    2018 Prius c
    it was designed to use a NimHi battery. GL getting it to work on a LiIo batt, you would need a NiumHi to LiIo converter controller.
  4. anas abu kaff
    anas abu kaff Junior Member
    jordan
    2015 Prius c
  5. royrose
    royrose Senior Member
    1,389
    949
    Foot of Pikes Peak
    Samantha rohana likes this.
  6. bisco
    49,489
    heck, in jordan, you can do anything you want.
    anas abu kaff likes this.
  7. JimboPalmer
    12,470
    6,862
    Greenwood MS USA
    The NIMH batteries are proven to last up to 20 years.
    No one has a Prius with Li-Ion batteries over 8 years old.
    What problem is it you are trying to solve?
