Questions for all you solar roofers
Discussion in 'Gen 3 Prius Main Forum' started by Soon-to-be, Apr 13, 2012.
  1. Soon-to-be
    Soon-to-be New Member
    bay area
    wondering a few things:
    Is mpg as good with the solar, given the extra weight?
    Any problems with leaves, ect, getting stuck? I park on the street and often find my car (civic) gets covered especially in the fall.
    Want it largely for the ventilation system to keep car cooler for the occasional times the dogs are with me when I am running errands though it doesn't often get above 68 degrees here so not sure it is worth it (but it looks great). Trying to decide on this feature as it adds a lot to the cost. This will be my first Prius and first new car in 20 years so want to do it right! Thanks for any help.
  2. ralleia
    ralleia Active Member
    386
    137
    Omaha, Nebraska, United States
    I don't have a Prius yet, but last year when I first was told what little the solar roof does, I guffawed and was dead-set against it.
    Now however I am seeking a Prius with the solar roof option.
    For one, the air to cool the traction battery for the Prius is pulled from the passenger cabin. So cooling that air may help prolong battery life. (This is my thought on it--I haven't done any research yet to substantiate it.)
    Secondly, even if your ambient temperature only gets to 68 degrees, the temperatures inside the cabin on a sunny day are going to be significantly higher.
    Third, I don't know that the solar roof really adds significant weight to the car. What little it adds is probably offset by the benefits of using the AC less and battery life.
    But I also wanted several of the features that come bundled with the solar roof, like the premium NAV.
    In any case, I no longer view the solar roof option as being useless.
    Regarding the dogs, keep in mind that the fan does not run continuously while you are out of the car. It is only set up to run when you are near to the car and turn it on. The maximum range is about 30 yards. NOTE: Another Priuschatter corrected me on this point in a later reply. It does run continuously, apparently. The car salesman told me wrong!
  3. fjpod
    fjpod Member
    419
    72
    New York
    I was at the NY auto show recently, and saw a high performance EV car. For the life of me, I cannot remember the name, but it was a Tesla like vehicle, and all their models had solar panels on the roof. The company claimed that they would provide UP TO 200 extra miles annually. Probably out in the Arizona desert with full sun.
  4. walterm
    walterm Active Member
    466
    202
    34
    2022 Prius Prime
    That's actually the 'remote AC' operation being described - the ability to turn the AC on before you get to the car.
    The main benefit of the solar panels is the ability to power a ventilation fan all the time the car is parked in sunlight bright enough to generate enough electricity. There is a switch you can turn that feature on and off with, I usually leave it on only in the late spring/summer months when it's hot enough to want the ventilation to run to exhaust the hot air that would build up. When it's 90 or 100 degrees it helps a lot!
    The main benefit to me of the sunroof is the availability of opening the roof on spring/fall days and enjoying the fresh air, and of being able to have more light in the cabin all the time.
  5. ghosteh
    ghosteh Member
    146
    57
    Illinois
    The concept behind the vent system is to keep the interior cooler so you don't have to run the AC as much. An added benefit to having the sunroof is that you can leave the shade open in the winter and let the sun warm the interior a bit.
    It would have been nice if Toyota had engineered that solar panel so that it was always working when the sun shines. That's free energy, and even if it's just a drop, it would help. I just don't understand why the solar system isn't linked to the main battery.
    I agree that the price of the sunroof is a bit steep, and I don't understand why it's bundled with the Nav option. Oh well, I got it anyway.
    It doesn't effect mileage in any substantial way, if at all. If you drive with it open, of course it's going to change your aerodynamics. But I wouldn't worry about the weight.
    Of course, the best option for leaving your dogs in the car would be to crack the windows AND open the sunroof. I wouldnt rely on the vent system to keep the interior temp the same as outside.
  6. Vardaman
    Vardaman New Member
    Chicago
    Does the sunroof actually tilt open when the solar fan is running? If it does, could someone post a photo?
    If it doesn't open, where does the fresh air enter the cabin? A/C vents?
    Thanks
  7. ghosteh
    ghosteh Member
    146
    57
    Illinois
    the air enters the cabin from the vents. The sunroof will not move unless you open it. Think of the sunroof & the solar vent as two seperate systems.
  8. css28
    css28 Senior Member
    1,566
    442
    Suburban Detroit
    You can opt to have the roof tilted open, and it probably makes it more effective (though the car will give you a warning tone when you're getting out). I leave the switch turned on all the time. Why not?
    I ended up waiting in the car the other day while my wife ran in for some groceries. The sun was bright (close to noon) and the outside temperature was 57 degrees. I had the windows open as well, but the fan came on from time to time with a good flow of air. I was impressed. It made it more comfortable to sit in the car. The roof was kind of dirt from driving in the rain a few days earlier but the fan ran strongly.
    Actually one advantage of the sunroof package is it means that 80%+ of your roof surface is glass, which is more toerant of bird droppings, etc.
  9. Yogi56
    Yogi56 New Member
    156
    26
    Escondido, CA
    We are moonroof buyers whenever possible and I like the gadget factor on the the Prius solar addition. I'm surprised how efficient the system is, it doesn't have to be a 90 degree day for system to work. I still get a grin when imhearnthe fan blowing upon entering. We live in San Diego and my wife uses the remote A/C at work when going to lunch and leaving for the day as temps can get high 90's inland in the summer.
    Resale is another bonus. When you do sell the car it helps your car stand out a bit from the others.
  10. ralleia
    386
    137
    Oh!
    Do you mean to say that the sales rep explained it to me incorrectly last year?!?? What a shocker. :p
    If he'd told me that it was on all the time that the car was parked in the sunlight, I wouldn't have every formed the opinion that it was a stupid idea. I couldn't for the life of me figure out why Toyota would only allow the fan to run for the minute or so that it took me to walk across a parking lot to my car. I've been carrying around incorrect information for over a year! :eek:
  11. pondcaster
    pondcaster New Member
    Columbus, NC
    +1 ~ Love the solar pkg. Wish it did more but does keep the interior nice & fresh. Looks great, too. No regrets!
  12. ralleia
    386
    137
    Actually, the effectiveness of the solar panel has nothing to do directly with temperature. Solar panels actually *reduce* slightly in efficiency at higher heat.
    It has to do with the amount of direct (and partly indirect) sunlight striking the panel. The insolation value of the sunlight in your location (watts per meter squared) is how you figure your amount of available sunlight. It varies depending on the location and time of year (and of course whether it's sunny that day).
    But don't think that the insolation value is going to be the amount of power that you'll get out of a solar panel. That's just the amount of sunlight energy that strikes one square meter, on average. Solar panels are only about 15% efficient at turning that light into electricity, so to get a reasonable figure you would multiply by 0.15. :D
  13. WE0H
    WE0H Senior Member
    3,247
    527
    The panel is rated 22v 3.6a in full sunlight. That is plenty to run into a battery charge controller to charge a 14v SLA or other smaller batteries. It should be enough to run into an inverter to make HV for charging the HV battery bank. Someone needs to try that.
    My use of my solar roof will be for the ventilation system and switched to a battery charge controller to charge my batteries that run my low power Amateur Radio equipment when I am out in the parks operating.
    Mike
  14. Tideland Prius
    16,128
    Even this far north, I still reap its benefits. Never having to sit in a sauna is a luxury that I didn't think I would really appreciate (like most here, I thought "oh ok, it cools the interior, that's a nice feature" but comparing it to the 2005 with a Bisque (beige) interior, my Dark Grey interior is much cooler. And yes, the added benefit is that when you start the car, the A/C has less work to do because the interior is already tens of degrees cooler than if you didn't have the ventilaton system.
    There are two parts to the Solar Roof.
    1. Solar Panel Ventilation System
    This is the one that uses the solar panels to power the fan motors (Which are beefed up compared to the non-solar-roof cars because they're expected to be running more often). This one opens the vent to fresh air (if it isn't there already) ~ 1 min after you turn off the car. After 10 mins, the SPVS gets to work, drawing in outside air and venting out the air inside (the 10 min buffer is so that the system doesn't vent out the cold air that you had inside as Toyota engineers assume you had the A/C running prior to parking the car).
    The amount of air depends on the amount of solar insolation that the solar panels can receive. The system will work intermittently in low sunlight too and of course run continuously in the peak of day in July when it's over 80F outside. There is a toggle switch to turn it on or off in case you park in a dusty area or, in my case, the coffee shop downstairs decide it's BBQ day and are BBQ'ing burgers outside at lunch time and I don't want my interior to smell like charcoal/ash.
    The SPVS will continue to run even if you unlock the car and open the door. It will shut off once you start the car or go to IG-ON. You'll have to wait 10 mins again before it'll start up.
    2. Remote Air Conditioning System
    To maximise the effect of a (relatively) cool interior, Toyota has kindly included a remote A/C function that turns on the climate control system. The A/C compressor in a Prius is electrically driven off the HV battery (high voltage or hybrid vehicle battery). A normal car's A/C compressor runs off the engine (with a belt) which is why you can't get A/C if the engine's off.
    To activate it, you press the "A/C" button on the remote keyfob. It will run for 3 minutes or until the battery is low (2 bars), whichever is first. It will also stop running if you open any door, including the hatchback. This is different from the SPVS which continues to run until you start the car. This way, you can load your shopping up and still enjoy the benefits of the SPVS while the Remote A/C is used once you're ready to leave.
  15. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    Answering another of the OP's question: the solar roof will slightly reduce mileage, due to increased weight and slightly worse aerodynamics.
    However, and this is a big however, note the word "slightly" - in practice I don't think anyone will notice the difference.
    Tom
  16. Tideland Prius
    16,128
    Oh yeah about the weight. It's ~30kg for the roof IIRC.
  17. Big Steve
    Big Steve ramblin wreck
    402
    39
    Richmond VA
    Am I right that you have to be pretty close to the car for the remote A/C to come on? In that case it can't have much effect on the temperature in the cabin, can it?
  18. HTMLSpinnr
    HTMLSpinnr Super Moderator
    5,339
    917
    251
    Surprise, AZ (Phoenix)
    One more thing worth noting - on really hot days, the black windshield cowling will pre-heat the incoming air. The air will thus be warmer than ambient inside the cabin due to that solar gain, but still less than it would have been w/o any ventilation at all.
    The remote A/C range is pretty minimal. The amount of time it takes to activate means that the vents have been cooled off slightly, but there's still no appreciable A/C effect on a hot day unless you stand outside in the heat and allow it to drain your HV battery.
  19. solarPiP
    solarPiP Junior Member
    Dallas, TX
    The roof panel isn't near big enough to charge the HV.
    I'm doing the math to set up a solar charging system for my PiP.
    To charge the battery fully in 6 hours of sun, you'd need approx 5ft x 20ft of solar panels.
    I was hoping for that too and spent months learning solar math to see if it was possible. FYI, the base setup for batteries plus panels to do it (at home, charging batteries during the day, charging the PiP at nite) is about $6k.
    *i'm not an expert, just starting to get this larger scale stuff figured out.
  20. WE0H
    WE0H Senior Member
    3,247
    527
    I guess the factory panel is only destined to charge smaller batteries for the Amateur Radio guys use :p The car would look silly with it's complete top side covered in solar panels for a HV charging system. Thanks for checking up on this.
    Mike :tea:
