Questions on rebuilding hybrid battery, make sure I'm on the right track
Discussion in 'Gen 2 Prius Main Forum' started by mohater, May 26, 2024.
  1. mohater
    mohater Junior Member
    51
    Fremont CA
    Hi folks, looking for guidance to make sure I'm on the right track.
    2005 Prius, 190k on the odo. Friend was throwing it away so I basically got it for a steal.
    Was giving intermittent transmission code. Usually on long drives when the back was full. Led me to believe it was a heat issue and the battery. Former owner informed me he got that code a few times. Code never came when the back was empty. Former owner also had cells replaced.
    I got the hybrid battery code for a few blocks, used a trusted source to do cell swaps, code came right back. Took it back to him and after working on it he described it as a cancer and would need a full battery pack swap or full cell rebuild. Got a lead on a gen3 battery with low miles (2012, 110k on odo). Did the full cell swap and got recurring hybrid code indicating blocks 8, 11 and 13, with 11 being the repeat offender.
    Got another different gen3 battery, did the full swap again, and getting repeating block 11 as the guilty party. Reading more threads on issues faced with rebuilds, it seems another common culprit is corrosion on the copper contacts for the cells and wiring. There is a decent amount of corrosion across everything (the blue raspberry dust).
    Checking resistance with the fancy Autel, and it's always 0.02 across all blocks, no deviation. Was the same with the other full cell swap. Revving the engine in park, it's always cell 11 that drops the most.
    Is another possible culprit the copper contacts as well as the wiring? Probably take it out and clean everything this week.
  2. ColoradoCrow
    ColoradoCrow Active Member
    967
    392
    Leawood, KS
    I
    Yes You are n the right track. Use vinegar and a toothbrush and scrub everything down to bare copper. 800 grit sandpaper for the bus bars is what I used. BTW. Wire Frame #2 at a toyota dealership for $85 saves you a lot of cleaning. while it is out I would inspect every cell and module for leaking, cracking etc. Clean your hybrid fan and make sure your temp sensors are put back correctly. Did you try clearing the codes and then re reading them? make sure you tighten the 8mm nuts to spec.
  3. mohater
    51
    Fremont CA
    Thanks for that. Given the amount of corrosion, will probably call the dealer Tuesday and order a replacement and then save and clean these for future use.
    Cleared the codes and driven many times. The system isn't happy with something about cell block 11.
    Temp sensors are working and reading correctly. I broke one sensor on the swap and ordered a replacement from ebay, replaced and it's operating as intended.
    What's the spec on the 8mm nut for the bus bar?
  4. ColoradoCrow
    967
    392
    Leawood, KS
    I
    48 inch pounds.....
    yes....Toyota states 48 inch pounds for the module fasteners, which includes the positive/negative terminals and the mounting fasteners that thread into the bottom of the module. If you really want documentation, I can hunt it down in the repair manual, or you can just google torque requirements for that size fastener (M5)
    mohater likes this.
  5. mohater
    51
    Fremont CA
    Thanks, just needed the value. Time to order, replace, torque and see what happens.
  6. mr_guy_mann
    mr_guy_mann Senior Member
    3,417
    1,477
    NJ-USA
    You will want to check the orange connector pins in the battery ecu for corrosion.
    I have many scantools, but when I want to monitor battery block voltages, I go for the Dr Prius app (with a compatible generic OBD adapter). That makes it easy to watch for high VOLTage DIFFerential between blocks (that would trigger codes.)
    In general, a "bad" (failed) module causes low block voltage on accel - discharge and high voltage on decel - charge.
    mohater likes this.
  7. mohater
    51
    Fremont CA
    Annoying thing there is need an android phone.... silly apple...
  8. mr_guy_mann
    3,417
    1,477
    NJ-USA
    Dr Prius works with ios, just need a compatible OBD adapter. See the Dr Prius site for details.
    Brian1954 likes this.
  9. ColoradoCrow
    967
    392
    Leawood, KS
    I
    I Run DR Prius.. on IOS with an iphone SE .
