Questions RE: HDD Navigation and NavTraffic
Discussion in 'Gen 3 Prius Audio and Electronics' started by FUUFNF, Nov 18, 2011.
  1. FUUFNF
    FUUFNF Forum Lurker
    210
    30
    Long Beach, CA
    Can anyone describe the differences between the DVD based navigation and the HDD navigation?
    Also, does anyone know if the NavTraffic integrates with the on-board navigation system - meaning, does the on-board navigation system automatically re-route you based on traffic data, or is that something you need to account for manually?
  2. MrPete
    MrPete Active Member
    424
    172
    Colorado, USA
    Not sure what you mean by DVD-based vs HDD-based. As far as I know none of the navigation-enabled head units make use of either a DVD or a hard drive for navigation?!
  3. FUUFNF
    FUUFNF Forum Lurker
    210
    30
    Long Beach, CA
    The navigation in my 2007 Prius was DVD based (all the maps, POI, etc. was stored on a DVD that was updated annually). I guess the "premium" navigation in the advanced package is HDD (hard-disk-drive) based, so all that stuff is stored on a HDD now... I guess the HDD version is supposed to be faster, but I never had any performance issues with the DVD version.
  4. MrPete
    424
    172
    Colorado, USA
    Perhaps you mean it was loaded from a DVD? I've never heard of a system that requires a DVD to be in place for navigation to work.
    All of these systems have some kind of "static" memory that holds the maps and software. It would be much too slow to pull maps on the fly from a DVD.
    The biggest difference would be that a DVD-based system is updated physically by shipping you a new disk... while other systems typically involve a download from the Internet that's then transferred to the nav unity. The latter costs less to the manufacturer, and can easily be updated more frequently, sometimes even through a live link from the head unit.
    So as you can see, DVD or not impacts frequency of update from the mfg but has no impact on navigation performance.
    Hope that helps!
    Pete
  5. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    Uh... considering your car has no factory nav system at all...
    I'm pretty sure my nav system will refuse to do anything (navigation-wise) if the disk is ejected.
    I'd imagine that the the memory you speak of would hold a small subset of what's on the DVD and presumably data for stuff near your current location.
    I can hear the DVD drive seeking on my Prius when I power up the car (it's faint). I've heard the (louder) DVD drive seeking on my friend's 04 RX-8 after powering up as well. I believe I've also heard seeking in my Prius when doing some searches. I'll have to double check both of the above when I get a chance.
    edit: I've confirmed my factory nav system has NO map functionality and tells me to insert the map DVD if the DVD is removed.
    If I remove the cover that covers up the slot and start entering destinations, esp. in other cities, I can faintly hear the drive seeking when I press on each destination.
