Questions to ask when I go in for recall
Discussion in 'Gen 3 Prius Main Forum' started by GreenGuy33, Mar 22, 2010.
  1. GreenGuy33
    GreenGuy33 Active Member
    534
    29
    Rhode Island
    I have an appointment this afternoon for the brake recall.
    When I mentioned the brakes pulsating and having a mind of their own when I go in reverse, the service rep. said he never heard of that.
    I have read about others on this forum having the same issue.
    Have you had your problem fixed?
  2. Prius 07
    Prius 07 Member
    715
    Toronto, Canada
    I suggest you take the car with the service rep for a test drive. You drive it (since you know the condition / circumstances) and let them drive it if necessary.
    Good luck,
  3. Prius 07
    Prius 07 Member
    715
    Toronto, Canada
  4. ScottG10
    ScottG10 Member
    132
    Bothell Wa.
    Some have found that after the sw upgrade, the reverse braking issue went away.
    I'd get it done and then recheck for the condition.
  5. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Make sure they hook up an auxillary power unit when flashing the ECU.
