Quick dumb question - ICE coolant
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by blacktouring, May 10, 2011.
  1. blacktouring
    blacktouring Junior Member
    45
    Rolling Hills Estates
    Ok, I did search this quite a bit but was not able to find the info I needed. Can anyone tell me if the ICE needs special coolant? Mine seems to have green coolant but I have heard about pink(?) coolant? I thought pink was only for the inverter.
  2. bigmike5
    bigmike5 New Member
    25
    San Jose, CA
    Both sides on a Prius (ICE and MG) use Toyota Super Long Life Coolant if I remember correctly.
    Its orangy-pinky.
  3. Patrick Wong
    18,200
    6,479
    The correct coolant is Toyota Super Long Life Coolant which is premixed with distilled water and has a pink color. If you see other coolant installed, that is incorrect.
  4. stefano5777
    stefano5777 Member
    380
    47
    St. Petersburg Florida
    Remember there are no dumb questions here on prius chat just dumb people!:eek: Just kidding:D As Patrick mentioned your Prius has wrong fluid if it is green I believe that is Honda's hybrid coolant which may be OK but I would recommend changing it to TSLLC
