Quick n00b question about sound in dash
Discussion in 'Newbie Forum' started by AnalogColor, Jun 14, 2010.
  1. AnalogColor
    AnalogColor New Member
    Atlanta, Ga
    Determining a good term to explain a sound is not easy. This makes search and explaining to a mechanic difficult.
    I bought an '07 Prius two weeks ago and keep hearing an intermittent sound coming from the drivers side dash (presumably from the engine compartment). The sound is similar to the motor inside a disk changer and only lasts about 1-2 seconds.
    My roommate copied me and bought a Prius 3 days after I bought mine, so I confirmed with him that he hears it too. From some brief research it seems to be a fluid pump for the engine coolant system?
    Thanks very much
    -Joe
  2. Doc Willie
    1,717
    142
    Out there, somewhere
    Is this a sound you hear while driving, or while parked after you have shut the engine off? In the latter case, the coolant pump is filling the thermos with coolant to keep it warm for the next start up. There is another sound several hours later as the fuel evaporation system is purged (I think).
  3. AnalogColor
    Atlanta, Ga
    This is while driving. It is pretty quiet so I didn't hear it today with the stereo on.
    It is quick and quiet so I never have time to try to find the origin. Sounds like a small motor so the water/coolant pump made sense to me.
  4. AnalogColor
    Atlanta, Ga
    Does anyone have any insight on this? I'm beginning to think it may have something to do with the brake system?
  5. richard schumacher
    7,663
    1,040
    United States
    Possibly the brake accumulator, but that should not run so frequently. If you did not have the car inspected thoroughly by a Prius technician before buying, then you should do so now.
