Quick question. Can I hook up my Iphone to a non-JBL system?
Discussion in 'Gen 3 Prius Audio and Electronics' started by D Unit, Nov 2, 2011.
  1. D Unit
    D Unit Junior Member
    Bay Area, CA
    Will the 3.5mm aux work if I connect my Iphone to my non-JBL system?
  2. Sabby
    Sabby Active Member
    295
    127
    SoCal
    Yes. If you have blulogic it will also stream music via bluetooth.
  3. Tideland Prius
    16,159
    Yes, any mp3 player that uses has a 3.5mm jack will work. You just need a male-male connector.
  4. D Unit
    Bay Area, CA
    If I use the 3.5mm jack, do I control the music using the Apple device or the Head unit? Blue Logic?
  5. stream
    stream Senior Member
    2,977
    452
    Long Island, NY
    The aux input is an audio-only connection, so it only transmits the sound & not anything else--you need to control everything (except volume) with the iPhone.
  6. D Unit
    Bay Area, CA
    Thanks a lot. Do you know if it's the same when using Blue Logic?
