Quieter Ride?
Discussion in 'Gen 4 Prius Main Forum' started by Iamjo20, May 26, 2014.
  1. Iamjo20
    Iamjo20 Member
    259
    Will the Gen IV have a quieter ride inside, and a smoother ride? Of course, mine is a Gen II, (only 21,000 miles) and maybe some of this has been improved since that time! :) It seems as thought the inside ride is very noisy in the Gen II and not overly smooth going over bumps in the road or the like. Looking very forward to the new Gen IV!
    49,371
    gen III isn't any different than II, so there's no reason to think IV will be, but we live in hope!
  3. cmth
    cmth Active Member
    279
    142
    UK
    I agree totally.
    At a minimum, I think we have a right to expect a quieter ride, or at least better dashboard/internal build material which do not add to internal noise. They need to test the car in roads with different surface roughness. Prius Gen3 suspension works fine in moderately rough terrain when driven slow - it manages to soak up the bumps well but in rough A- Roads like the ones we get here in Scotland, the entire cabin can feel the vibrations even at average speed - this is not good for a £20k car.
  4. Iamjo20
    Iamjo20 Member
    259
    Well darn........do dealership still do "undercoating", and would that even help? There HAS to be a way to achieve a quieter inside cabin ride! LOVE my Prius and truly am waiting for the Gen IV!!!!
    And maybe different tires would help?
  5. mmmodem
    mmmodem Senior Taste Tester
    2,732
    1,703
    Bay Area, CA
    Of course there is! You can use Dynamat or similar insulation for the interior. They do this at car stereo shops. You can also swap out the fuel efficient but loud LRR tires for quieter touring tires.
    Contrary to other replies, I found the Gen 3 Prius much quieter than the Gen 2. Much of it is owed to the larger engine I suspect. I expect a similar bump in refinement in the Gen 4.
    I thought the undercoating was to mitigate rust from road salt?
    iPhone ?
    mozdzen likes this.
  6. Iamjo20
    Iamjo20 Member
    259
    Thanks..........any brand of touring tires? Have you or has anyone had the dynamite installed, and results?
    I did know about the undercoating for up North for salt; thought it might also have some sound deadening assistance!
  7. bisco
    49,371
    there are some threads here with dynamite installation and great results. don't know if the search function is working yet.
  8. Iamjo20
    Iamjo20 Member
    259
    I actually did find them! Thanks ! :)
    Also, recommended touring tires? or "All season" tired--for Florida- for a quieter ride---Michelin? Pireli? OR?
  9. mmmodem
    2,732
    1,703
    Bay Area, CA
    Michelin MXV4 are the best touring tires I've ever purchased. Currently running a set on my Hyundai Sonata and car barely hear any tire noise. My friends installed Dynamats to reduce rattle from body panels vibrating against each other when the stereo is turned up. So I never got the chance to experience the car as being quieter. ;) Here's a youtube esxplaining the process.
    Iamjo20 likes this.
  10. Iamjo20
    Iamjo20 Member
    259
    Thanks so much for the info! I do not have rattles from body panels; mainly inside cabin noise when driving , so do not know if that is due to poor floor insulation or/and the original tires! What about floor/carpet padding--would that help road noise? The Michelin--Is that the Primacy MXV4?
    #10 Iamjo20, May 28, 2014
  11. mmmodem
    2,732
    1,703
    Bay Area, CA
    Honestly, I'm not the best source for touring tire recommendations. I only purchased the Michelins for my Accord and they came stock on my Sonata and I've been impressed with them. I did my research on tirerack.com.
    I suspect to decrease weight and cost, Toyota used minimal padding on the floor, door panels, etc. That's basically how luxury vehicles keep the noise out. They use thicker foam padding and thicker windows. Not much you can do about the windows but you can certainly add foam padding like Dynamat.
    iPhone ?
    Iamjo20 likes this.
  12. bisco
    49,371
    michelin energy savers are supposed to be quiet and good LRR's. be careful about mpg loss when tyre shopping.
    Data Daedalus likes this.
  13. Iamjo20
    Iamjo20 Member
    259
    Is it better to get LRR's as opposed to 'touring" tires dues to MPG loss?
  14. bisco
    49,371
    oh most definitely. i'm not an expert on touring tyres though.
  15. Felt
    Felt Senior Member
    1,624
    603
    Mountain West
    About 30-40k miles back I installed Michelin Energy Saver tires on my G3 (2010) and I could not be happier. In addition to improved fuel efficiency, the noise was reduced significantly. They still have many miles of tread remaining.
    In the west, the highway department lays a thick coat of some sort of asphalt slurry then lays and rolls smooth a layer of pea gravel on top. I am sure the road wear is reduced, but it is considerably more noisy than smooth asphalt. Scored concrete (improved traction in snow and ice) is also noisy.
    Iamjo20 and cycledrum like this.
  16. goldfinger
    goldfinger Active Member
    535
    402
    Buffalo
    Maybe the New Global Architecture will stiffen things up reducing rattles. Then again it could be a tunning fork conducting all sources of noise into the cabin where they can resonate. Old cars with frames could isolate frame noise from cabin to some degree. They also had lots of heavy sound damping and sound absorbing materials.
    With the gen IV's 20% decreased weight I don't see allot of room for sound control. Then again you never know.
    Ecopia ep422s made my 2005 allot quieter and great mileage.
  17. praecurvo
    praecurvo Junior Member
    34
    Boulder
    I too look for a quieter ride in the Gen IV Prius. How about better sound deadening all around? From the roof to the floor and everywhere else. With newer materials, acoustic modeling, and active noise cancellation, the Gen IV Prius has an opportunity to be noticeably quieter.
    We owned a GEN III and got rid of it for two reasons. Not enough sound deadening and just a hair to little room in the back seat. We'd really like to get into another Prius, so eagerly looking towards the Gen IV's release ASAP. Otherwise, 2015 VW Sportwagen TDi is in our future.
    Iamjo20 likes this.
  18. KennyGS
    KennyGS Senior Member
    1,243
    1,044
    Keystone State
    As far as Toyotas go, you could just buy an Avalon and be done with it.
  19. Mendel Leisk
    38,644
    Great results, lol??
    Seriously, I've found our prius pretty quiet, comparing to past Hondas.
    #19 Mendel Leisk, Aug 20, 2014
  20. KennyGS
    1,243
    1,044
    Keystone State
    Everyone's expectations and desires are different, but I'm happy with mine too. I knew it wasn't going to astound me with its ride quality, but for what it was designed to do, I think it does a very nice job. (y)
