Quoted £200 for Fob duplicate. Is that normal?
Discussion in 'Gen 2 Prius Main Forum' started by Mih_Ka, Dec 9, 2020.
  1. Mih_Ka
    Mih_Ka New Member
    United Kingdom
    My local Toyota dealer (London) said he’d charge £120 for the Fob and £85 to programme it. He said only authorized Toyota dealers are able to make duplicate keys. I just wanna know if the price is ok and whether it’s true that dealers are the only ones able to make dupes. Thanks
  2. PriusCamper
    PriusCamper Senior Member
    13,432
    5,422
    Pacific Northwest, USA
    If you just want to add a single new FOB and your system isn't maxxed out at number of FOBS yet, there's a way to program that FOB by entering commands into the car using door locks and other components. Just google "Chicken Dance PriusChat"
    However if your FOB is not new or you no longer have an existing FOB to match a new one up you can DIY it by buying a Mini-VCI dongle and install Toyota Techstream on an old Windows computer and then use this service to wipe and re-seed all your FOBS to the car: Lexus, Scion, Toyota PASSCode Calculator / Generator: Calculate Pass-code by Seed number | Immobilizer Pincode Calculator
  3. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    The quoted price is within range. If you have a "fully functioning" key to work from, you could try to program the replacement yourself.
    Doing a search here uncovered numerous threads for the DIY process, try this thread first : How to Program a New Key Fob for Full SKS Functionality | PriusChat
    Perhaps this thread is more your speed : Finally! How to program a non-SKS key/fob. Detailed! | PriusChat
    PriusCamper likes this.
  4. qmanqman
    qmanqman Active Member
    444
    153
    CO
    Your dealer is FOS. Ace Hardware can also do them.
    Automotive Keys - Ace Hardware
    I see you're in the UK which means you probably don't have an Ace Hardware. Nonetheless, it means that Toyota dealers are not the only place it can be done.
    SFO likes this.
  5. SFO
    SFO Senior Member
    5,302
    4,251
    Northern California
    Never knew this was a viable option, even with the fairly high end keys pictured on that page, I am still having some doubts.
    Have you (or anyone known) ever used the FOB programming services being offered by ACE before?
  6. qmanqman
    444
    153
    CO
    Yes I have. My Accord has some weirdo double sided key that's hard to cut and the Ace machine couldn't pull it off. Luckily I didn't really need the physical key. I just needed a new fob programmed. It's just a machine they plug into the OBDII port. There's a process they follow to program the FOB and viola, new fob works.
    SFO likes this.
