Rabbit Guards??
Discussion in 'Gen 3 Prius Main Forum' started by lumpy95, Mar 20, 2018.
  1. lumpy95
    lumpy95 Member
    394
    63
    Mojave Desert, Cal.
    Out here in this rural area of CA. the wet season has brought MANY Rabbits this year. Unfortunately one of them got into my garage and chewed up the Oxygen Sensor wires and 1 of the transaxle boots.
    It's gonna cost me approx. $700.00 to have them replaced. Is there any way to "Rabbit Proof" my Prius??
    m.wynn and Mendel Leisk like this.
  2. frodoz737
    frodoz737 Top Wrench
    4,297
    2,348
    33
    49,446
    traps? dogs? are you parked outside?
  4. David Beale
    David Beale Senior Member
    5,963
    1,981
    Edmonton Alberta
    They will even chew on the tyres. Metal around the cables will stop them. Aluminum foil is easiest. They don't like the taste of aluminum.
  5. lumpy95
    lumpy95 Member
    394
    63
    Mojave Desert, Cal.
    Parked in a garage but I assume it snuck in as I was taking the car in/out of the garage. I have walked around the garage and there is no other entrance to get in other than the roll-up door or walk-in door.
    I did set a trap and caught 1 but the 1 that chewed into the wires etc. had evidently received enough of a jolt to incapacitate him. It was still alive but really messed up. I put it out of it's misery.
    The tip off that something was wrong was when I pulled the car out of the garage and saw Rabbit puke and a large urine stain on the concrete. I didn't realize that the urine would turn the concrete pure white.
    Aluminum foil is a good suggestion but that big gap ( in my first picture ) is an entrance to the whole engine compartment.
  6. lumpy95
    lumpy95 Member
    394
    63
    Mojave Desert, Cal.
    Thanks, that might be a viable option to spray around the garage doors. I had heard of a different repellent spray that stinks to high heaven but the stuff you suggest "supposedly" doesn't stink.
  7. pilotgrrl
    pilotgrrl Senior Member
    891
    1,796
    Chicagoan in TX
    The ingredients are rosemary oil and mint oil, so it shouldn't smell bad to you, unless you can't stand either one.
    Capsaicin/capsicum products are supposed to be good too, they had those at my local Menards, which was in IL. Unfortunately, no Menards in TX.
    lumpy95 likes this.
  8. lumpy95
    lumpy95 Member
    394
    63
    Mojave Desert, Cal.
    I just tried to order from Menards and the ordering process keeps becoming unresponsive so I'm not sure I can get it. I also noticed that the minimum order is 6 which becomes quite expensive.
    I did find it by googling though, as a 1 bottle purchase.
    Animal Stopper Animal Repellents
    #9 lumpy95, Mar 21, 2018
    pilotgrrl likes this.
  9. padroo
    padroo Senior Member
    2,763
    2,250
    Was the damage covered by your car insurance?
  10. pilotgrrl
    891
    1,796
    Chicagoan in TX
    Wow, I haven't had that kind of problem. Maybe it's just that store. Go to their store
  11. pilotgrrl
    891
    1,796
    Chicagoan in TX
    Oops, hit the send button too early!
    Go to Menards store locator and try the store on North Ave in Glendale Heights, IL. It might just be that store, which apparently is the closest one to my GPS location.
  12. lumpy95
    lumpy95 Member
    394
    63
    Mojave Desert, Cal.
    I have a $500 deductible so I may as well pay it myself.
  13. lumpy95
    lumpy95 Member
    394
    63
    Mojave Desert, Cal.
    I just ordered 1 bottle from the link I posted previously, $17.99 w/ shipping.
  14. lumpy95
    lumpy95 Member
    394
    63
    Mojave Desert, Cal.
    If it works, I'll get more.
  15. pilotgrrl
    891
    1,796
    Chicagoan in TX
    Hope it works!
    lumpy95 likes this.
  16. Lucifer
    Lucifer Senior Member
    1,014
    485
    Nh
    I use a tiny ultrasonic device in my carport and another in my garage, both have two vehicles, the truck used to have a rats nest on the battery, the cars used to have daily signs of rodents, in the four years they've been plugged in zero signs of rodents, this link is to a larger device, the company also sells a six pack of smaller devices.
    SFO likes this.
  17. StarCaller
    StarCaller Senior Member
    1,246
    697
    Cedar Crest, NM, USA
  18. lumpy95
    lumpy95 Member
    394
    63
    Mojave Desert, Cal.
    Thanks for the suggestion but I'm not sure that would work for Rabbits.
    BTW, the link didn't come through for the product.
  19. lumpy95
    lumpy95 Member
    394
    63
    Mojave Desert, Cal.
    Well, the repairs are done, $654.00. The spray I ordered won't be here until Thursday the 29th, so hopefully it works around the roll-up door and the walk-through door.
    I guess Elmer Fudd had the right idea behind hunting Rabbits "I hate Wabbits".:)
    pilotgrrl and Mendel Leisk like this.
