Race to the bottom!
Discussion in 'Gen 3 Prius Fuel Economy' started by Kermit262, Dec 28, 2010.
  1. Kermit262
    Kermit262 Member
    112
    45
    Central Ohio
    It's clear from my MPG chart (measured at the pump) that there's a direct correlation between MPG and temperature. But unlike others, I've decided to embrace the decline! I figure by Feb. 28 I should be getting negative 2 MPG. ;)
    Bob
    2010 Prius III
  2. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Looks exactly like mine. LOL, embrace the decline. Looks like a hockey stick after a good season.
  3. Felt
    Felt Senior Member
    1,624
    603
    Mountain West
    Hey .... think about the positive. On March 1st, you will start seeing an increase in fuel efficiency. Winter is tough on all vehicles: cold starts, heater use, pushing through snow, and do not forget winter blend of gasoline.
  4. Former Member 68813
    3,524
    981
    US
    Good thread. People should start bragging about poor MPG. That should cut on numbers of new threads like "MPG lower than advertised" and "Toyota doesn't care."
    Let me state for the record that the lowest MPG I get is when drive for 1 mile: under 25MPG (sometimes as low as 17MPG when it's up hill).
  5. Kermit262
    Kermit262 Member
    112
    45
    Central Ohio
    Initially I got distressed seeing my MPG dropping, but then I put it into perspective. I'm still getting better gas mileage than I ever got with any of the other cars I've owned, even in the best of conditions. So no worries - as Felt said, it'll go up soon enough. :)
  6. mainerinexile
    mainerinexile No longer in exile!
    403
    73
    Maine
    Temperature, length of trip, and no doubt tire PSI all control winter mpg. I'm still getting near 50 mpg despite cold temperatures and studded snow tires, but I don't commute with the Prius and generally drive 20 minutes or more when I take the car out of the garage (yes, the car starts at 50 degrees, regardless of outside temperature.
  7. Erikon
    Erikon Active Member
    819
    105
    Rochester, NY
    Got 17mpg yesterday running to the supermarket and back, 22 degrees and 0.6 miles!:D
  8. xs650
    xs650 Senior Member
    4,539
    1,433
    Northern California
    You need to find a market further from home, a lot further.:D
  9. Rokeby
    Rokeby Member
    3,033
    708
    75
    Ballamer, Merlin
    This thread, with a more descriptive title ;) , should be a sticky.
    Here are two graphs posted by Tony Schaefer that show winter mileage
    reductions are inescapable realities.
  10. Former Member 68813
    3,524
    981
    US
    WOW! This graph alone should be sticky.
  11. coach81
    coach81 Active Member
    758
    116
    Louisiana
    So when it's cold.. the MPG goes down a bit.. got it!
  12. ETC(SS)
    6,493
    Don't worry coach.
    I'm on the coast, and my current tank is 58.2mpg/302miles/42 average mph.
    If you ever get to pull the trigger on a Prius, you'll do OK during the winter...:cool:
  13. odaigle
    odaigle New Member
    35
    Canada -- Montreal
    Sure cold weather hits the fuel consumption. Here is a 1 year log of my fuel consumption (calculated at the pump). I also observed that the discrepancy between the displayed FC and calculated FC is higher when the temperature is cold. I will post the error graph later on.
    Note: car bought November 26th 2099.
  14. spiderman
    spiderman wretched
    7,543
    1,558
    Alaska
    Cool, wait till Daniel sees this. :D
