Racing Prius?
Discussion in 'Gen 2 Prius Accessories & Modifications' started by slvr_phoenix, Jul 4, 2007.
  1. slvr_phoenix
    slvr_phoenix Tinker Gnome
    84
    To start off, if you're not going to contribute positively to this thread, please don't post. I don't need to hear anything about why messing with the factory delivered setup is a crime against humanity or any such.
    The concept: To show the world that a hybrid vehicle that still gets good gas mileage can also move. It'd start out in autocross racing because I think a Prius would do well there.
    Of course I don't have a million dollars to drop into my Prius to do this all at once, but the plan goes as thus:
    Step 1 ) This one is easy because I know what I need exists and will work. All of the Tom's stiffening mods. TRD Sportivo suspension mod. Motegi Traklite 17 inch rims (14lbs each) with 205 or 215 wide racing tires. This should give the Prius a lot better handling, maybe even enough to avoid the traction control dropout problems.
    Step 2 ) Brakes! Can better disk brakes be put into a Prius? Does anyone know of any? With links? (No arguments about how regenerative braking makes it pointless as in a racing environment you're going to see the real brakes actually get used a lot more often.)
    Step 3 ) Horsepower? The Prius with its high torque will do well in autocross, but to squeeze even more horsepower out of a Prius would be helpful. With such low horsepower in play, even a 5 or 10 hp addition could make a world of difference.
    Step 4 ) Superbattery in the trunk to run 'in the green' for an extended period of time. There have been plenty of plug-in concepts that use this to improve the Prius fuel efficiency. But this should also improve the performance. I'd prefer not to use lead acid batteries for a number of reasons, but I'm not sure what a suitable better option would be as all of the new battery technologies never seem to come out. Has anyone heard of any real definitive deliverable yet?
    Again, please keep this thread clean. It's not about your average drive for a Prius. (Though keeping it street-legal is still intended.) It's about showing the world that better economy doesn't have to mean bad performance. It's about getting people talking. Did you see that Prius race?! I was amazed! A Prius? And I hear it still gets 45MPG! You don't even have to win to get people's attention. So please help me. What can I do to make the best of it?
  2. hyo silver
    hyo silver Awaaaaay
    15,232
    1,563
    off into the sunset
    Hey, it's your car. If you're thinking of racing it, check out what modifications are allowed for whatever class the Prius fits into. Stiffening the chassis sounds like a good place to start. As for brakes, you could try stainless lines and see what fits from the Toyota or TRD catalogues in the way of bigger discs and calipers. The land speed record car used an Echo engine, so an engine swap may be the way to get more power. Adding extra batteries to the trunk shouldn't be a huge problem, though you may need to reprogram some software for everything to work smoothly. Good luck!
  3. jdenenberg
    jdenenberg EE Professor
    3,852
    1,854
    Trumbull, CT
    2020 Prius
    LE AWD-e
    <div class='quotetop'>QUOTE(Silver Phoenix @ Jul 4 2007, 02:59 PM) [snapback]473014[/snapback]</div>
    There was an article reporting the addition of a turbocharger to an early Prius. It helped and a 5 lb boost worked out (more can cause error flags). It was not an easy adaptation.
    I also saw a remote install turbocharger (It can be mounted anywhere on the car) that may deal with the space limitations in your Prius engine compartment. Good luck.
    JeffD
  4. bobdavisnpf
    bobdavisnpf Member
    149
    Endless has Prius racing calipers in development:
    Tom's has performance pads for the stock calipers, I think. B)
    Tom's also has a performance muffler. B)
    K&N has a new replacement air filter assembly:
    http://www.knfilters.com/news/news.aspx?ID=526
    They say it's a lifetime washable element and that it improves performance and mpg. :unsure:
    After adding all the Tom's braces and the TRD Sportivo suspension kit, you'll probably want to get in ot the group-buy for the all-around skirt package. B)
    For tires & wheels you may want to go more aggressive than 205's. I think a set of 235's on 17/7.5 inch rims would be minimal. 245's on 18/8's would probably require 1/2" to 1" spacers but I think would give you much better racing stability. Going to racing slicks or to UHP summer tires is a must. B)
    A magnetic oilpan plug would help keep the engine clean. A thinner oil and a fast-flow oil filter would help too. Finding a ATF radiator might be a good idea, along with checking out better transmission fluids for racing type operation. :huh:
    Then, of course, there's always the turbocharger - don't know who has done this - and Nitrous Oxide... :lol:
  5. apriusfan
    apriusfan New Member
    6,050
    205
    S.F. Bay Area
    Unless you are wanting to start some sort of green autocross category, you are going to have to compete against MINIs. Even the N.A. MINI is going to be a serious challenge to overcome. Things like lower overall weight, multi-link rear suspension, chassis rigidity, large selection of big brake options (up to 13 inch rotor diameter), all manner of handling options (shocks, springs, sway bars, etc.) and the like are what you are up against. Horses for courses....
  6. bobdavisnpf
    bobdavisnpf Member
    149
    <div class='quotetop'>QUOTE(apriusfan @ Jul 4 2007, 10:35 PM) [snapback]473348[/snapback]</div>
    If the prius can make it onto the track at all, it'd be a win. Once we're on the track, we can start talk of a green category... maybe requiring a PZEV emissions threshold and test pre-race... I understand other races have pre-race inspections for all sorts of things, from wing and fender positions to fuel composition to exhaust manifold volumes...
    Besides, even Nascar is tipping its hat to the environment: unleaded fuel is phased in as a requirement this year.
  7. apriusfan
    6,050
    205
    S.F. Bay Area
    <div class='quotetop'>QUOTE(bobdavisnpf @ Jul 5 2007, 08:04 AM) [snapback]473454[/snapback]</div>
    That they do (have inspections for category conformance). It would be possible to tweak a Prius for competing against other Hybrids and personally, that would be an interesting race to watch. But a general autocrosser the Prius is not.
  8. subarutoo
    subarutoo New Member
    1,213
    23
    Chatsworth, CA
    I autocross a Subaru Impreza that is modded to STS class. A couple of evasive highway moves in the Prius surprised me with the handling (in a good way). As for weight, the Impreza and Prius are about the same. Where the Prius has 295 ft.lbs. torque and oppressive traction control, the Impreza has 165 lbs torque and AWD. In straight line accel, I've beaten an Impreza similar to mine, at last up to legal speed limit. Off the line it's great. For autocross Prius needs more roll stiffness, less understeer, and more tire. It might be a fun project, but I wouldn't clear off the trophy case just yet. If there is enough interest for a Hybrid class, it might be worth it, but there are too many better suited cars out there now to be competitive. Don't sweat the brakes too much. I think the Prius brakes are just fine for autocross. I love my commuter Prius, and I love my autocross Impreza. Horses for courses.
  9. jweale
    jweale Junior Member
    I just recently noticed that Sigma Automotive's Prius page has a picture of a Prius labeled "Solo2 F Street." I would think running down the goods on that would be a good start. If you do, let me know - a quick google turned up nothing for me. I'd love to take a Prius (just ordered a touring model last weekend) autocrossing rather than my old '89 Porsche 944 turbo. I need all the excuses I can get...
    A Honda Insight embarassed a lot of people in the SF Bay area region for a while. Very lightweight car and a good driver posted some decent times, as long as he started with a fully charged battery. It was really apparent when he ran out of amps during a run. Eventually the driver sold it and moved on, since while he did amazingly well it seemed the car couldn't crack the top ranks.
  10. Pinto Girl
    Pinto Girl New Member
    3,093
    350
    The Prius' simple suspension and high center of gravity will always work against you, especially in competition...I've considered going down just this road (do a search of previous topics).
    Get rid of the Atkinson Cycle mill if you can. There was that turbo Classic but even the folks who built it said that it was a difficult project. There was also the Prius GT, that had more HP but, again, was an Otto. Again, I don't know how the top end of the engine was modified to work with the PSD, etc...but it was a factory effort.
    Chassis-wise, there are all sorts of TOM's braces. Brake-wise, the Prius doesn't seem to use the stock brakes that much, even in aggressive driving; why you'd actually need those four-pot calipers designed to dissipate loads of additional energy, I honestly don't know.
    The tires are also too small, as are the wheels; the discs are also of a small diameter...and of course, the rears are drums, so brake balance isn't so good. Then there's the feeling-less electric steering, and the traction control, which cuts engine power when a wheel even thinks about slipping...
    I love my car, and I flog it at regular intervals (the TRD suspension and other things help a bit)...but it's no Porsche 993 (which I came out of) and never will be. Without its own category, I don't think it has a chance. Too many weird systems designed for economy, not performance.
    Good luck to you. I think (but hope I'm wrong) that you'll find that this project will turn out to be more expensive than you'd suspect, and the returns might not be as substantial as you'd like.
    Let us know how you do...at this point, I'd like to find a salvaged Pri, fire up the torch, and drop in a smallblock V8...
  11. Family Hybrid
    Family Hybrid Junior Member
    87
  12. patsparks
    10,664
    567
    Adelaide South Australia
    Has anyone thought about fitting a second standard battery pack for more hybrid oomph? Isn't it one of the highest energy density batteries around? Safer and lighter than lead acid. If it's purely for racing remove the back seat and put extra batteries in that space. For a standard look put the seat cover back over tha battery. Will another hybrid battery like from a Camry or the SUV version sold in USA fit in place of the back seat.
    Not cheap but nothing is in racing.
    Change the head on the Atkinson cycle engine, there is nothing wrong with the Atkinson cycle crank position, it's the late closing inlet valves that reduce power. Will the Yaris head fit? You need to remap the VVTi, EFI, and ignition as well.
  13. kohnen
    kohnen Grumpy, Cranky Senior Member
    317
    57
    Fullerton CA
    <div class='quotetop'>QUOTE(patsparks @ Jul 27 2007, 09:02 PM) [snapback]486479[/snapback]</div>
    Um,
    The thing that makes it an Atkinson cycle is the late intake valve closing. The offset crank position is done to reduce friction; the Otto cycle Yaris engine does the same thing.
    So, I guess I don't quite understand your point. Could you clarify?
  14. JaviNOS
    JaviNOS Mod Freak
    150
    Puerto Rico
    you could go from atkinson to otto.. get everything trd offers.. and toms...
    then there is not much going on for the engine performance but you could try and fit a cold air intake even if its a custom built one (but thats when you go to the otto cycle).. then you should go lighter... a lot...
    get rid of everything... the seats, the dash, the speakers.... then maybe just maybe you're getting somewhere...
    if you succeed in the otto conversion and get something like a yaris engine you may find a few stuff to pump up power...
    and most of all some $$$ and some luck and some good connections or convincing attitude to get some sponsorship :D its not an easy task but good luck
  15. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    I've been thinking about this one for a while.
    A couple years back, I went to the autocross in oakland.... er... i think it's oakland. ( i don't cruise there often )
    I believe there is a hybrid category. The people were excited to see me. several people commented that they wanted to see a prius try it. I was told i did pretty good. I was not the lowest time. ( i can't recall the numbers )
    my tips: make your car a semi plug in. this way your main battery will always be full. ;) ( at the end of the race my battery was dead. I had to force charge it. ) Don't force charge. it's bad on performance. ( this is why i say phev ) stiffen the entire car with all the braces you can. replace the suspension. Don't increase the brakes. you'll wreck the whole point of the car. If you want to brake faster, just hit them harder ( it's not all that bad )
    Turbo charge it. Pay a shop to pick one out and install it. try to make them give you a warranty on their work, the unit, and the stability of the prius. ( good luck on that one. i wouldn't try it.) Leave the exhaust alone. Leave the intake alone. ( changing those would kill the purpose of the car )
    Have fun. take as many pics as you can. post them all. start a webpage. share it here. Let me drive your car ( last one optional of course)
    I side on the opinion of not destroying the car. It's a clean hybrid. Leave it as a clean hybrid. Make it an awsome racing... clean hybrid.
    just my $0.02 cents..... sorry.. that's my fee. i don't like donating ( just kidding)
  16. HighBreed
    HighBreed Member
    113
    Los Angeles/Orange Counties
    It's nice to show the world that you can have fun too autocrossing a Prius on weekends.;)
  17. fruzzetti
    fruzzetti Customization-Obsessed
    377
    California (Pulled over 6x, ticketed 2x for tint)
    There are a lot of good ideas on this forum. In fact, there are enough to start someone tinkering who has the time and car.
    But you guys are NOT thinking about how to really optimize the car; we should be playing into its strengths and compensating for weaknesses.
    (1) Manual control over the CVT ratio range. Give me a lever like any stickshift, with a short throw and the ability to move in two directions smoothly: toward me (higher gears; higher speed) and away from me (lower gears; higher acceleration). And it needs to have much faster reflexes.
    (2) Don't commit suicide replacing the weird ICE. Play to its low-RPM strengths. It works, therefore it is ready to be improved upon. More aggressive fuelling with computer-controlled NO2 injection, alongside a more open exhaust system, should get you an easy 20-40 safe horsepower; probably substantially more if you're willing to start taking risks or having parts machined in more exotic materials. This is a very good route, though!
    (3) You don't want to upgrade the batteries until you're absolutely sure you need to. Remember, gas mileage isn't a problem, so running the engine constantly to keep the batteries charged is also not a problem, especially considering the nitrous oxide power boost.
    (4) If you DO think you need a battery upgrade, it's because you're right and you've taken the wisest of all electric drivetrain upgrade decisions: in-hub rear-wheel motors calibrated to throttle computer to match the front-end drivetrain.
    It needs to be reclassified after these alterations as a "multiply parallel hybrid electric" vehicle, but so what? :D You have a synthetic all wheel drive system that has flexibilities unheard-of up to now - before that the slowest relative speed you could apply at one tire was zero. Now one wheel can turn backwards to change the drift pattern or automatically help recover from a spin.
    Dot, dot, dot...
    ~ dan ~
    And yes, I know it would require infinite money, infinite monkeys, and infinite typewriters... But if I had anywhere near infinite money I'd already be making my race Prius :p
  18. JaviNOS
    JaviNOS Mod Freak
    150
    Puerto Rico
    I completely agree... could not say it any better... than what you just did Fruzzetti
  19. fruzzetti
    377
    Imagine using that CVT for a drag racing car. The engine could be tuned totally differently than usual. Instead of trying to have a reasonably high, mostly level power curve, you could align freakishly steep torque and power curves with enormously high, but short, peaks; then you use the CVT to just keep the engine in the high-power range for the whole trip. You could shave half a second off any car's ET and it frees you to develop an engine with a less balanced design which also means less cost.
    ~ dan ~
  20. slvr_phoenix
    84
    Hi everyone and thanks for the input. Between hectic life changes (new relationship, moving cross country, job change) I just haven't had money and time to do much with my Prius. And with all of the problems I had just accessing this forum, I'd kind of forgotten it even existed for a good while.
    But every so often I wistfully think of making my Prius proud, and I finally buggered back here to ask some more and see what's up.
    So I had this thought. I read in several articles on the Landspeed Prius project that they replaced the stock Prius gas engine with a stock Yaris gas engine. (Since they're essentially the same engine just without the artificial limiter in the Prius to improve gas milage.) Yet in all of the articles I look at now, every one of them claims the Landspeed Prius was a totally stock Prius engine. 1 - What's up with that? Were they lying back then about using a Yaris engine or lying now about it being a Prius stock engine? And 2 - Can we Prius owners just switch the Prius engine back to a Yaris engine by removing / changing a couple of parts?
    Because as far as I can tell from what research I can manage with Google, the Prius engine is just a Yaris engine with the redline knocked 1000RPM and the computer instructed to never redline the engine. (Which probably removes yet another 500-1000RPM.) But other than that, they're the same engine.
    Why is this so important? Well look at the stats. Same engine: Prius 76hp / 85fl-lb torque vs Yaris 106hp / 103ft/lb torque. So if Prius owners could make this change, you're talking about an upgrade of 30hp and 18ft-lb torque. I'd kill to just be able to remove that artificial limit in the Prius to suddenly gain that much. But can it be done, and if so, how?
    It's also nice to see some real brakes being worked on for the Prius. I know the regenerative braking of the Prius engages most of the time so the real brakes are barely used. But the Prius has one major flaw in its braking system: the traction control. As soon as any tiny loss of traction kicks in the Prius stops using the regenerative braking. So all of the sudden your only braking comes from those crappy little grossly undersized brakes on the wheels. And drum brakes in rear at that! It's a legitimate danger in snow. And it's a legitimate danger when racing. So changing out the stock brakes for real ones would at least make the Prius safe in both inclement weather and in racing. In my opinion every Prius owner should seriously look into that just for safety reasons. I've been complaining about this problem with the Prius almost since I first got mine, since I was going through a Wisconsin winter just months after purchase. It's scary. It's dangerous. And I still can't believe Toyota hasn't been forced into a recall because of it.
    (Sheesh do I wish I could just disable the traction control on the Prius. In Wisconsin it has almost been the cause of more accidents than it has ever "saved" me from. Every time I have to drive my Prius on rain, snow, or ice I shudder and hover one hand over the engine brake. And don't even get me started on the winter MPG loss...)
    But I also agree that the Prius just plain sits too high for racing. A suspension change to lower it would be a must. I know the TRD suspension kit for the Prius lowers it a little, but I have to wonder if there aren't even lower suspensions for the Prius out there. I don't want Landspeed Prius low, just ... lower.
    And if I could afford all of this (hopefully ... one day) I'd also most definitely look into a plug-in mod with extra battery. To green-line the battery charge and super-size that green-line runtime would make a huge difference in performance. And the regular driving MPG boost from making it a plug-in should more than offset the MPG loss from engine and tire upgrades.
    So again thanks for the input folks. Let's keep the thought alive! :) What new products and thoughts
    can we throw at making the Prius something to turn heads, not as a pretentious green machine, but as a fast and sexy green machine.
