radaitor blocking powered damper???
Discussion in 'Gen 2 Prius Main Forum' started by lextoy, Nov 22, 2010.
  1. lextoy
    lextoy Active Member
    291
    131
    philadelphia
    2018 Prius Prime
    i am no expert on the prius electronics, but i cant help wondering why noone has put together a kit to automatically block the radiator in colder temps, unblock in warmer temps.
    obvious gains in mpg, and readily available damper systems, should be easily adaptable to our needs.
    HVAC dampers are avaialbe in all shapes and sizes. this one i found comes spring loaded to fail open... or spring loaded to fail closed(better for prius),
    can be custom sized to any dimension, i think our radiators are about 24 wide by 14 tall???
    4" deep so should fit in front of radiator with minor mods.
    motorized, motor can be mounted on side or on top or bottom, so ideally placed to fit in a prius.
    only problem is what to wire it to, independent Tstat control, or integrated into prius system. its 24 V also, but any decent electrician or HVAC person should be able to figure out how to turn the motor.
    its all aluminum, so easy to cut and modify, and add brackets to with sheet metal screw or rivets, and easy to cut extra holes in louvers along bottom row, for example, for full time partial ventilation of inverter loop.
    i am no engineer, but some of you are very skilled, i wonder why noone has gotten this solved, or is it jsut not necessary, easier to shove pipe insulation into the grill;)lol
    http://www.zonefirst.com/products/ZD.pdf
    opticell likes this.
  2. lextoy
    291
    131
    philadelphia
    2018 Prius Prime
    can probably retrofit a 12 v motor for less than 4 dollars. maybe even order it with a 12v motor,
    or order it with no motor at all. pop in a 12 v.
  3. lextoy
    291
    131
    philadelphia
    2018 Prius Prime
  4. lextoy
    291
    131
    philadelphia
    2018 Prius Prime
    who knows exactly when the cooling fans turn on?
    when the AC is running YES
    AC ON above 25mph ????
    AC ON below 25 mph ????
    when required to cool the engine below 25 mph YES
    when required to cool the engine above 25 mph ????????
    as i have read, cooling fans almost never come on, even in summer heat, except when called upon by the AC
    so we could probably simply hardwire the damper motor to the fan motor, fans on damper open, fans off damper closed. assuming the damper is sprung closed in the off position.
    only question is then, will engine know to turn on fans in a high temp, high speed run.
    like going down the highway at 70 mph in 90F degree heat...???
    temps below 50F not a problem, nothing heats up in winter temps
    short trips below 15 miles not a problem, nothing heats up until after about 10 miles
    lower speeds 0-40 mph not a problem, ICE intermittent, MG intermittent
    only problem is high speed, long trips, high temps, how does prius stay cool then, normally airlfow provides ample cooling, even though ICE and MG are running more strenuously, but if you block airflow??
    if fans would come on intermittently while running, then it would be fine.
    is normal airflow in summer temps too much?? aka does the prius actualy get too cold when running at high speed in high temps??
    has anyone monitored unblocked temps in the summer to see if ICE stays hot or gets too cool???
  5. mort
    mort New Member
    16
    Los Angeles
  6. lextoy
    291
    131
    philadelphia
    2018 Prius Prime
    ahhh;)
    but the damper could be automatically adjusted for optimum temps year round,
    insulation requires daily monitoring, and attentive owner.
    damper could be dummy proof.
    why toyota doesnt do this is beyond me...
  7. Patrick Wong
    18,198
    6,464
    1. Incremental cost
    2. No customer demand for that feature
    Note that starting in 2011, auto manufacturers will need to perform fuel economy tests in cold temperature operation. That might prompt some manufacturers to devise a damper design.
    Regulatory Announcement: EPA Issues New Test Methods for Fuel Economy Window Stickers | Fuel Economy | US EPA
    Also note that the fail-safe mode should allow the damper to be fully open, since that would provide maximum cooling for the engine compartment, thus providing highest reliability. If the fail-safe mode was for the damper to be shut, then the powertrain would be impaired under hot ambient temps.
  8. don_chuwish
    don_chuwish Well Seasoned Member
    816
    180
    Southern Oregon
    It's a common topic at EcoModder. I've seen several threads where someone has an idea for it:
    Arduino controlled actuated grill block
    Lower Grill block that can open and close
    Active grill block idea
    One from Chevy:
    Chevrolet Cruze Eco to Have Variable Geometry Air Shutter for Better MPG : TreeHugger
    But personally I think if this is going to be done it should be louvres that are flush smooth with the bumper when closed, not hiding behind the open maw of the grill. They should open/close in increments as dictated by engine temperatures, not ambient temps. Faster warmup in all conditions and most likely closed at speed for better aero.
    - D
  9. ken1784
    ken1784 SuperMID designer
    2,940
    1,359
    67
    Yokohama, JAPAN
  10. lextoy
    291
    131
    philadelphia
    2018 Prius Prime
    aha!!!!! very sweet, looks to be manual control? still requires driver to monitor temps. love the integration into bumper, instead of wedging btw grill and radiator.
    very small, not much larger than a license plate.
    could a Tstat be wired inline to actuate when coolant reaches specified temp?
    easy to tap a sensor into radiator inlet.
    just monitor sensor along with scangauge engien temps to figure out what best temp would be to open damper.
