Radar Detector & Remote Start question
Discussion in 'Gen 2 Prius Audio and Electronics' started by kdmorse, Nov 5, 2005.
  1. kdmorse
    kdmorse Member
    205
    Germantown, MD
    Two short questions as I keep my eye on a fully loaded 2006 Prius. They're simple - as I know nothing about car wiring, and even less about the Prius's wiring.
    Can a radar detector be direct wired into a Prius just like any other car? If so, when would it come on? Would it turn on if you just pressed start (foot off break), or not until you 'started' the car (foot on break), or when you disengage park, or...
    And would it be possible to add an additional switch, so you could manually cut power to it from a switch on the dash or on the console even when the car was running. (ie - when passing through Virginia, where Radar Detectors are illegal)
    There's a section of my weekly commute that runs through Virginia for all of 3 miles, and they sit there scanning for people who forget to turn off their radar detectors when entering VA.
    Secondly, on a Prius with SKS, is there any way to add remote start capability. I realize remote start on a Prius is quite a bit less profound of an option as it is on a normal car, but the ability to start the car generating some heat a few minutes before I hop in (be it just to warm up the car, or to melt a thin layer of snow/ice off the glass) in the middle of winter is a incredible convienience.
    Ohhh... silly question just came to mind. Could a body shop add a sun/moon roof, or am I just being *really* silly now?
    Thanks,
    -Ken
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    You could wire it however you wanted. No special reason it couldn't be made to activate at Ready or IG ON or ACC mode and adding a switch just means putting one on the wire to the power cord.
  3. efusco
    19,891
    1,192
    Nixa, MO
    I think someone's mentioned that adding a remote start is possible, but it is not easy. Also, unless you set the car to defrost before you shut down at night it will only run for a short while before the ICE shuts off.
    IMO, a better option that will actually help you reduce emissions and improve fuel economy while still getting fairly quick warm-up would be to add an Engine Block Heater. Look under the "Performance Mods" forum for a long recent thread on this subject and where to order.
    I know of 1 or 2 people who've added moon/sun roofs. They're pricy, they throw off the aerodynamic shape of the roof (have you ever seen one from the back?), and they can't be very large. But again, given enough money and the desire it can be done.
  4. Bill Merchant
    Bill Merchant absit invidia
    4,096
    81
    First, I have neither a radar detector, remote start, nor sunroof.
    There are several circuits that energize as "accesory", meaning they are live when the car is READY or ACC ONLY or IG ON. You could wire your radar detector to one of these circuits. Don't most radar detectors have a power switch on them? Couldn't you just kill the power that way?
    The ceramic heaters in the Prius start putting out warm air almost immediately. The hot coolant pumped back into the engine on startup gets engine heat to the heater quickly. If you're in the area of Virginia, you're not really in a cold climate. There may be aftermarket remote starts, but you get into all kinds of troubles since you have to have a fob in the car or in the dash to start it, so your security really drops, particularly since the car tries to prevent you from locking the fob in the car.
    A few people have installed sun/moon roofs as mods. Search and ye shall find.
  5. IndyDoug
    IndyDoug New Member
    120
    Indianapolis, IN
    Driving below the posted speed limit would solve your radar detector issue as well as improve your MPG.
  6. Wayne
    Wayne Active Member
    723
    27
    Fort Wayne, IN
    I agree, in fact most of what you want to do will lower your mileage. You will probably be back here right after you get your car asking why the mileage is only 38... :huh:
  7. efusco
    19,891
    1,192
    Nixa, MO
    I got a lot of the same responses when I started posting questions about radar detectors back in mid-2003. I was defensive and stated that I drove ~10mph over the limit and didn't intend to change with the Prius. I said I thought it was safe and I was a good driver, but wanted the 'buffer' of a radar detector to avoid a ticket.
    A month after getting my Prius I transformed into a speed-limit driving Type-B personality driver when in my Prius. It was like a switch was turned. I enjoy driving the speed limit. I'm more relaxed, I don't get pissed when people cut me off (unless it's really dangerous). I've increased my following distances dramatically and I no longer accelerate to stop lights/signs.
    My radar detector is in the glove box of my car and it's been almost 2 years since it was mounted on the windshield. I have no idea why I even leave it in there. I specifically chose the one I have b/c it talks and sounds very cool. It even says something like "READY" at just about the same time the Prius goes into READY mode upon start up. But I just don't need the thing and it was more of a problem of getting in the way of my sun visor than it was any kind of help in preventing tickets since I just don't speed any more.
    YMMV, but I'd definately drive the car for a month or two before paying to have the radar detector installed or buying one for it. You just might find you don't actually need/want one after all.
  8. kdmorse
    kdmorse Member
    205
    Germantown, MD
    I'm replaceing a 12 year old Saturn Stationwagon, with a dying engine, and a dying transmission. I've got oil seeping into the engine, misfiring sparkplugs, and probably only one cylinder actually running correctly, and it likes to shift gears randomly on it's own. Current MPG: 11.
    *Just* getting 38MPG would be a hoot. I may occasionally drive extra gingerly on a tank or two just to see what I can get the MPG up to, but in general I plan to drive fairly normally and let the car do what the car does.
    If remote start requires a fob be left in the car, then that's simply out of the question then.
    As to the Radar Detector through VA issue, you can easilly get pulled over for just having one on, regardless of whether you're driving the speed limit (25mph) on that stretch of road. They've got a whole well organized trap out there just waiting, and they get dozens of folks a day.
    I currently have the unit mounted somewhat out of convienient reach (ie - the power button's not easilly accessable), so the ability to cut it off from a switch on the console comes in quite handy.
    As to the speed limit under other cirumstances, while the limit's 65, if you don't drive 75+ you'll get run off the road. And coasting downhill in neutral you can easilly hit 85. It just pays to know when you're being watched...
    Who knows, I may 'convert' to a gentler driver. But for now, I do enjoy zipping along... (For the record - havent had a ticket or accident in 15 years)
    -Ken
  9. Wayne
    Wayne Active Member
    723
    27
    Fort Wayne, IN
    Oh my. I've heard that so much -- "If I don't drive fast, I'll be run off the road!" That simply isn't true. Even if it is, just drive many car lengths behind a semi. They will see the semi and switch lanes long before they get to you. Going back to the "it isn't true" part -- people whiz by me, and they never seem to have a problem doing it.
    "Coasting in neutral". Another bad idea. There are threads on this. Little to gain.
    I'll ditto what Evan said. I never wanted a radar detector, but I was a type A driver that always drove 10-20 miles per hour over the speed limit. It was like a switch was flipped when I bought my Prius too -- I now drive the speed limit or below. I have NO desire to drive faster, and it is SOOOO much more relaxing (and law abiding!) And I don't have a single problem with anyone around me.
    Listening to you, the bottom line is you are going to do what you are going to do, even if it cuts your mileage in half, which it will. So do yourself a quick favor, and check out my signature -- you will find a MPG vs MPH test there. Check what it says at the speed you wish to drive, so you're ready for the reduced fuel efficiency you will get. ;)
  10. Subversive
    Subversive New Member
    251
    I like to drive fast too. Fortunately, I live in Massachusetts, where any ticket for less than 10 miles over the speed limit is automatically thown out of court, so no cop will write them out for this, unless possibly if you are in one of the areas marked with "speed limits enforced with zero tolerance" signs, or perhaps if you are zipping around a college campus at night or something. And on MassPike and I-495, in the areas where the posted speed limit is 65MPH, one can pretty much blow right past cops holding out radar guns at 79MPH without incident. After all, most speed limits are about revenue generation rather than safety--if the legally required engineering studies to determine safe traveling speeds were done at all on a road, they were done with equipment that is using the driving abilities of an octogenarian driving a Studebaker, not a fully competent driver using a modern vehicle.
    But with all that said, gas mileage is still very important, and it will drop significantly the faster you go. And the great gas mileage is undoubtedly one of the primary reasons that we all have bought or will buy a Prius. And as a previous poster said, it is actually a lot easier to drive at a slower, relaxed pace in the Prius, because of the reinforment provided in the display. No, it's not a cure-all for me, at least not yet. My commute already takes an hour each way, and I have no desire for it to take an hour and fifteen. But I'm experimenting and trying to compromise. For example, I make an effort to drive more slowly on the way home because I am not in as much of a hurry, and I try to drive more slowely on the non-freeway half of my drive relative to the speed limit than on the freeway half, because I think the mileage payoff is bigger on that end of things. But as I said, I'm experimenting.
    In regards to speeding tickets, I'd like to direct you to the National Motorists Association at http://www.motorists.org/ . They are an immensely valuable resource in helping you fight speeding tickets and unfair traffic laws (and you should always fight speeding tickets).
  11. kdmorse
    kdmorse Member
    205
    Germantown, MD
    In a Prius, of course. I don't *have* a Prius yet! Things are a bit different in a stationwagon :)
    -Ken
  12. Jaguar88
    Jaguar88 Member
    172
    La Crescenta, CA
    I've had a car with a sun roof and thought it was great but unless it is installed by the manufacturer; I have always wondered how it affects the structural integrity of the car's design.
    I don't know if there are any accident statistics on a moon roof but I have always thought they were less safe.
  13. chrisek
    chrisek geek
    94
    Carson City, NV
    kdmorse, To be more specific to your question, I am working on that now. Because there is no power port in the bottom of the dash (somewhere around the stereo head unit), you will end up attaching your radar detector to the ignition cables (pretty common) so it will only turn on when you turn the car on (this is the route we are going with our Valentine One).
    What you may not already know is that the windshield is waaaaay the heck in front of you, I mean out of reach. One idea I thought of is to bring the cords "back" towards you and have a 2 position switch ("on" and "off") then run the cables forward to the radar detector. This way there is something handy to power it on and off at your convenience.
    Further, I have my wife's parking permit (school) just above it and the Fastrak next to it to make it less visible from the front. I don't know if you are in need of "camoflauge" or not, just a thought.
    To each their own on how you drive, my wife isn't slowing down from her 85mph commute speed and is excited about her 42-43mpg. My commute speed is artificially restricted to 10mph over in daylight and 5mph over at night due to my accumulation of speeding tickets. I hope to resume in January when I get my "speeding ticket school" available to me once again. Your driving habits may change and they may not, but the security of a radar detector is for you to decide.
    PS. You will truly enjoy the car once you get it. B)
  14. darwin100
    darwin100 New Member
    131
    I agreee driving the Prius has totally changed the way I drive....my radar detector is in the glove box...
    I would love a moon roof as well....if anyone ahs the modification would you post pictures...and give details...
    thanks
  15. hdrygas
    hdrygas New Member
    3,650
    Olympia Wa
    I have a question. I had a radar detector years ago and I thought it was just a receiver. How do the cops know you have one and if it is on? Do they see the led on light? Seems like a bet of black tape would fix that. I thought you could install the unit in the grill and have a remote alert in the car so the cops would not know you have a detector? Here we have a lot of laser in use here. How do you protect against that? I have also slowed down since getting my Prius type A to B shift. Obviously I am now out of date on radar detectors.
  16. BobR
    BobR Member
    336
    This was posted on www.speedcameradefence.com:
    What is VG-2?
    All detectors made in recent history are superhets. This means they have oscillators which send out a weak, but detectable signal. Some genius decided to take advantage of this fact to make a product to sell to liberty-loving governments the world around. He called it a vg-2. The cops hold this black box which simply detects the presence of a detector. A new crime is born! Your defence is a detector with vg-2 shut down. That is, the detector senses the signals put out by the cops black box and shuts down its oscillator. It's still basically a quick draw contest between your box and the cop's box, so if you're in one of those fun-loving places like Virginia, D.C. Ontario, Quebec, France, Belgium, Switzerland, New South Wales, etc. where they'll confiscate your detector; get yourself a detector which puts out far less signal to detect in the first place.
    http://www.speedcameradefence.com/faqs/index.asp#faqAnchor6
  17. GeekyDragon
    GeekyDragon New Member
    93
    Santa Cruz, CA
    I've got a V1 mounted top/center of the windshield (hooked onto the sun glasses holder). The wire runs under the headliner to the A-pillar (backside of the airbag) and then down beneath the dash where I tapped into te plug beneath the dash. Works great and I can easily adjust/turn off the detector.
    As for spped, don't believe the hype. We carpool in the Prius 120miles a day and average 75-85mph. We average 48-50mpg (calculated at the pump not MFD). As long as your a consistent driver and don't do anything to sudden you'll get prett good mileage.
    Now, as for those who'll criticize the exess speed, get over it. We're not unsafe drivers, we don't do anything rash or stupid and we slow down when appripriate.
    --GD
  18. keeponrunning
    keeponrunning New Member
    46
    Birmingham, AL
    I too was a big time speed demon. For 20 years I never got behind a weel going less than 10 over the speed limit. Now I am doing 8 - 10 under, and DANG happy to do that.
    Sounds crazy but WHY would someone be happy with 38 MPG when you can get 58 MPG by slowing down?? 5 - 10 min extra on my commute adds an extra 10 MPG on ever gallon of gas I put in. an extra 100 miles per week I add by just slowing down... tough choice (OK, not really).
    I gave my radar detector away. Not needed, never will be again. All I need to see is my consumption guage showing 58+ MPG and I'm a happy camper!!
  19. DanMan32
    DanMan32 Senior Member
    3,799
    26
    Tampa Bay, FL
    Technical note on the power system.
    Most of the devices in the car are powered just as car audio amps are. They are given their main power through a constant 12V, and are turned on through ACC, Ig1 (Ig-On) or Ig2 (READY) feeds. These feeds use a 7.5A fuse, since they are only used to turn on the devices, not to supply current.
    The power outlets are a bit of a different animal. Each are fused by 15A. The console outlet 15A fuse is fed from a 25A fuse that is powered through a relay energized at ACC. The 25A fuse is shared with the 7.5A fuse I mentioned.
    The dash outlet is turned on by a relay that is turned on by the console outlet power. The relay contacts are sourced by 15A constant 12V. Coastal's mod simply jumpers the relay contacts.
    So, if you power your radar from one of the 7.5A fuse, you might overload the fuse. Taking power from the outlet is your best bet.
    Alternately, you might be able to use a spare fuse slot in the driver dash J/B.
