Radial spare a replacement spare tire for 2013 Gen3?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by ElecTomato, Jul 22, 2021.
  1. ElecTomato
    ElecTomato Junior Member
    Maryland
    Hello All, the spare donut tire type named on the inside of the driver door of my Prius Gen 3 is T135/80D16. All 4 of my regular tires are radial ply.
    I am wondering if a different donut spare, a "Firestone Radial Tempa Spare" T135/80R16 will work. It seems sturdier than the spare the car came with.
    Does the ply make a difference? Isn't radial ply supposed to be better with heavier loads? Why does the car come with a diagonal/bias ply spare?
    Thanks
    #1 ElecTomato, Jul 22, 2021
  2. PriusCamper
    PriusCamper Senior Member
    11,092
    4,515
    Pacific Northwest, USA
    Pretty much anything will work as long as the bolt pattern matches up... But if you want to take good car of your car and you get a flat front tire... Put the spare on the rear and the full size rear tire up front. This is better for the transmission because both wheels will be the same diameter and rotate at similar speed. And while driving a short distance with a donut tire up front is probably fine to do temporarily, avoiding different wheel size or even different tread depth up front is worth the effort.
    Georgina Rudkus and ElecTomato like this.
    49,442
    And follow the rated psi and speed restrictions.
    Get a good tire back on asap
  4. Mendel Leisk
    38,708
    The OD of the stock spare is pretty much identical.
  5. PriusCamper
    11,092
    4,515
    I'm curious about that... Will take a tape measure to the donut next time I pull it out... Seems so much smaller, but from an engineering and design perspective that would make the most sense.
  6. ChapmanF
    15,568
    They pretty much have to make it close enough to avoid wheel-speed-difference errors from the skid ECU (at least up to the maximum speeds intended for the donut spare).
  7. Georgina Rudkus
    Georgina Rudkus Senior Member
    3,165
    2,209
    Taylors, SC
    If you are really worried about compatibility, get a full size spare with tires identical with your current tires. In an emergency, nothing beats a full size spare. For me, it worth the loss of space.
    ElecTomato and Grit like this.
  8. PriusCamper
    11,092
    4,515
    My old Subaru had enough room for a full size spare tire in place of the donut... Doesn't work so well with a Prius... But way better than a plug-in prius that doesn't even have donut.
  9. Mendel Leisk
    38,708
    If you check the spec's, say on TireRack, you'll see they're VERY close. See-is-believing: stack the temp atop the stock, on a flat slab, align on the faces on one side with a carpenter's square, then go round the other side and repeat. The temp is maybe 1/8" shy of stock dia, on our 3rd gen, doing that.
    PriusCamper likes this.
