Radiator bleeder valve stripped, what should I do?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by MiaTwo, Dec 3, 2019.
  1. MiaTwo
    MiaTwo New Member
    Las Vegas
    I was replacing my water pump and was almost done, just had to bleed the radiator and fill it with coolant. Unfortunately I used the wrong size Allen key and stripped it.
    I now have no coolant and a stripped bleeder valve. What should I do I can't even get to the stripped part because the metal housing is in the way.
    Is removing it a big job? Any links or guides on what I can Do?
    I'm debating just trying to drive it to a mechanic but don't want it to overheat. If I put coolant in it without bleeding it will I destroy the car?
    Is there another way to bleed it and fill the coolant without using the bleeder valve? Any help would be really appreciated.
  2. JC91006
    16,482
    8,400
    Did you try with a proper size allen wrench? I know your smaller one isn't working.
    Mechanics probably don't even use that bleeder valve, they use a vacuum device when putting coolant in the car, no bleeding necessary.
    To answer your question, you should try to tighten the bleeder valve and then put coolant in the car.
    1. Run it with the heat on high until the car gets hot air blowing and keep adding coolant until it's full and the level doesn't go down anymore. Put on the radiator cap and let it run for a minute. Turn off the car and wait til it cools.
    2. When the car is completely cool (will be a few hours), open the radiator cap and fill the coolant again until it's full. Repeat a few more mornings and you should be good.
  3. Mendel Leisk
    38,727
    Is it loose or tight now? I'm guessing tight?
    Is it possible to get vice-grips or some sort of pliers on it, to break it loose?
    There should be replacement readily available: check with dealership parts department.
  4. MiaTwo
    MiaTwo New Member
    Las Vegas
    When trying to loosen it, it made a sound that I think was the valve opening. So it may be open, but I don't know how to tell. I think the coolant got sucked in when opening the bleeder valve, but it was also just spilling onto the floor since I used a regular funnel and didn't know I was supposed to use a no-spill funnel. So I don't know if it's open or close.
    Is there a way to find out? Should I just see if I can pour coolant into it?
  5. Mendel Leisk
    38,727
    If the bleed valve is open it would turn easily.
  6. MiaTwo
    MiaTwo New Member
    Las Vegas
    Ok thank you. I think it's closed then.
  7. JC91006
    16,482
    8,400
    whatever you do, don't drive without coolant in this car
    jzchen likes this.
  8. valde3
    valde3 Senior Member
    2,002
    745
    Finland
    If bleeder is still closed you should be able to bleed the system without using it. Bleeder is in the driver side of the radiator so what you need to do is to lift the passanger (front) side up when filling the coolant to stop air from collecting there. Because the system is hard to bleed anyways you may need to go back and forth with tilting the car. With many hard to bleed cars I have just driven up to a hill while bleeding. Look for the bleeding instructions to find how to bleed the heat storage system.
  9. Mendel Leisk
    38,727
    Here's a pic of the radiator bleed plug:
    13 in/lb torque is more-or-less one ft/lb.
    ^ Try this first. Maybe try to grip it with serrated jaw pliers at the same time, turn the two in tandem. If possible.
    More info in the attached.
    Danny S likes this.
  10. Mendel Leisk
    38,727
    Danny S and JC91006 like this.
  11. wbeck
    wbeck Junior Member
    Atlanta, GA
    I had to replace my Prius 2nd Gen Bleeder Valve because it was completed corroded and the 6mm hex key wouldn't turn it. I hammered a flat screwdriver into the old plastic bleeder valve and turned it counterclockwise to take it off. Here's a photo of the new parts (bleeder valve and O Ring), part numbers, and location of the bleeder valve.
