Radiator Coolant is Low
Discussion in 'Prius v Technical Discussion' started by KingKhan, Mar 24, 2019.
Tags:
  1. KingKhan
    KingKhan New Member
    Los Angeles
    2012 Prius V Radiator Coolant is very low. It shows on the bottom of the container. I noticed when I saw the low coolant light on the dashboard.
    I filled the container and it went down again the next day. No low coolant light is on yet.
    It’s not the gasket, I didn’t see in the engine when I opened the oil cap.
    I’ll be changing oil soon.
    49,500
    how many miles on her?
    anything under the car?
  3. PriusVirgin
    PriusVirgin Junior Member
    Mission Viejo, CA
    Head Gasket-using coolant internally. Does it run rough at start up? No leaks-coolant has to be going somewhere-Most likely internal consumption.
    49,500
    turned out to be a cracked rad hose
    Air_Boss likes this.
  5. Air_Boss
    Air_Boss Senior Member
    3,952
    1,083
    New Yawk
    Occams Razor delivers again...
