Radiator plug replacements (likely aftermarket)
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Johnny KIlo, Sep 8, 2015.
Tags:
  1. Johnny KIlo
    Johnny KIlo Junior Member
    51
    Chicago suburbs
    I destroyed my radiator drain plug and purge plug (not on purpose) and Im having a hard time replacing them. I am 99% sure the radiator is aftermarket. I bought the one Autozone said is the replacement but it's way too small. There are some numbers on the radiator itself but I couldn't find anything online. Looking for any advice.
    thanks
    #1 Johnny KIlo, Sep 8, 2015
  2. M in KC
    M in KC Active Member
    358
    106
    KC, MO
    Try your dealer as that part looks OEM or an indy radiator repair shop.
  3. CooCooCaChoo
    CooCooCaChoo Senior Member
    899
    501
    Cow-lee-fornia
    2023 Prius
    You might be able to grasp the little stub that is left with a pair of pliers and open it. Orientate the pliers like so:
    Radiator drain cock (that's what its called :p) -x V pliers
    Might not work like this -x > pliers
  4. Johnny KIlo
    51
    Chicago suburbs
    The reason this was such a pain is because the *&@*&# that "fixed" my car before selling it to me put a drain cock, a rather large one at that (had to be careful with my wording there), in the coolant temperature sensor. I realized when I saw a normal radiator that had the drain cock on the side, this also explained the loose connector in my engine bay.
    Funny story I actually had 2 water pump bolts break off in the engine block, I'd take the chewed up drain cock over those bolts any day of the week.
