Radiator Removal, replacement
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Wince, May 20, 2017.
  1. Wince
    Wince Junior Member
    Can anyone share any instructions, diagrams or manuals on how to remove the main radiator (for the ICE) in a 2010 Prius. I have a pin hole leak spraying out through the blades of the passenger side fan down low. All coolant leaked out suddenly but we caught it immediately and the computer did not thrown any errors, especially related to overheating. The inverter coolant does not seem to be affected and I understand it has a separate radiator. Is this true?
    I suspect I will need to replace the main radiator and will consider doing this myself if I can find some good documentation.
  2. ChapmanF
    15,614
    Other than the obvious at techinfo.toyota.com?
    -Chap
  3. Mendel Leisk
    38,726
    Inverter radiator is a short piece at the top. You're sure it's the radiator, not the AC condensor? Coolant level is dropping in the reservoir?
    The main "radiator" at the front is the AC condensor, the engine coolant radiator is behind, and the inverter coolant radiator the aforementioned short radiator, at front and top.
    #3 Mendel Leisk, May 20, 2017
    ImranAs'hab and gliderman like this.
  4. Wince
    Wince Junior Member
    Thanks Mendel and Chap. Just the resources I needed to make the decision. It's definitely the main radiator....i filled the overflow reservoir with distilled water and it came back out a hole in the radiator on the side facing the engine. It squirts out about 3" with about 1 gallon in there and the car off. I assume if the car were on it would be under more pressure and drain faster. Fortunately we caught it at home so I have a place to work on it.
  5. NavyLCDR
    NavyLCDR Active Member
    188
    120
    Stanwood, WA
    I would be very interested to know how the radiator R&R goes for you. I have a bent radiator support bracket that I need to replace sometime but it looks like a pretty involved job to R&R the radiator.
  6. Wince
    Wince Junior Member
    Well I've decided to have a radiator shop put it in for me (not the dealer who charges about twice as much). The diagrams shared are great and I'm convinced it wouldn't be that hard but I only have about a 5 hour window in the next 2 weeks and if I can't complete it I'll be waiting a several more weeks before another window. If I had more time I'd do it myself. Thanks again for the contributions.
  7. Prius4lif3
    Prius4lif3 New Member
    Sacramento
    Four Touring
    I'm working on a bent radiator support as well, how long did that take you?
  8. ImranAs'hab
    ImranAs'hab Junior Member
    JORDAN
    Thank you dear for the manual..
    How or from whare can i get the complete manual for 2010 prius..
    Thanks in advance
  9. SB6
    SB6 Member
    314
    69
    Repair manual
    I can't find the original post right now, but someone on priuschat had shared this
    #9 SB6, Jul 6, 2020
  10. Dmanke
    Dmanke New Member
    Cocoa Florida
    You don't have that same file on a 2013 pruis v do you. I need to replace my cooling fans. And like to know the steps to do it
  11. ChapmanF
    15,614
    A while back, Elektroingenieur kindly assembled a wiki page with a lot of information on getting access to the manuals and other service information.
  12. Mendel Leisk
    38,726
    The Prius v might be identical. Sorry don’t have v manual; suspect Toyota ceased PDF format??
  13. Coasty
    Coasty Junior Member
    Oregon
    Question for Mendel Leisk and others:
    I was told I need to replace my radiator and hoses. This is a 2007 Prius, Touring model with208,021 miles. The headlight glass is so scratched on the passenger side, that I thought the bulb needed replacing. Question: since they are taking off much of the front end to replace the radiator, is this a good time to:replace both headlight casing units as well? I’m hoping to keep this Prius going to 300,000 and beyond, if possible.
