Radiator with minimal leakage, what can be done?
Discussion in 'Gen 2 Prius Care, Maintenance and Troubleshooting' started by Lavi2005, Nov 10, 2019.
  1. Lavi2005
    Lavi2005 Junior Member
    israel
  2. valde3
    valde3 Senior Member
    2,002
    750
    Finland
    Where does it leak from? Some areas like filler neck can be repaired. But if not just get a replacement radiator.
    SFO likes this.
  3. Lavi2005
    israel
    Is there a little leak in the radiator upstairs, maybe glue, or powder-clogging powder?:/
  4. Leadfoot J. McCoalroller
    8,144
    7,645
    Pennsylvania
    2018 Prius c
    Radiators are relatively cheap and replacing them isn’t hard.
    Now, cleaning out an engine block, thermostat housing and a couple of water pumps full of sealer gunk? That’s hard.
  5. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    752
    Delaware
    I believe I saw a solid aluminum replacement radiator on ebay. that would be way better than the junk plastic tanks on the oem radiator.
    SFO likes this.
