Radio antenna connector type?
Discussion in 'Gen 2 Prius Audio and Electronics' started by kieran, Nov 26, 2007.
  1. kieran
    kieran New Member
    Ottawa
    Hi Folks,
    What type of antenna connector is on the back of the OEM radio? I wanted to add a modulator but wanted to ensure I have the correct type/connector/adapters before I started the project?
    Kieran
  2. Skwyre7
    Skwyre7 What's the catch?
    2,332
    Richmond, Virginia
    It's a standard antenna connector. I don't know any more than that. I hope it helps. I've got a Sirius wired FM modulator plugged into mine and it fits just fine.
  3. Banjoman
    Banjoman Member
    124
    Orange County, CA
    <div class='quotetop'>QUOTE(kieran @ Nov 26 2007, 09:36 AM) [snapback]544294[/snapback]</div>
    Yes, it is a "standard" automotive antenna connector.
  4. kieran
    kieran New Member
    Ottawa
    Thanks for the response. I just wanted to add the Sirius modulator and didn't want any surprises :)
  5. Skwyre7
    2,332
    Richmond, Virginia
    The only surprise I found when I installed mine was some change that had somehow gotten stuffed under the passenger side floor mat. (I found it when I was re-routing the wires.)
  6. DocToss
    DocToss Junior Member
    69
    Cordova, TN
    I want to ad the xm fm direct kit. Does anyone have a pic of the back of the 06 radio? And can this be done without removing the radio?
  7. Skwyre7
    2,332
    Richmond, Virginia
    Theoretically it can be done, but it's much easier done by removing the radio. It's not difficult to do, just a little scary having your dash taken apart.
    I don't have a picture of the back of the radio. Sorry.
  8. kieran
    kieran New Member
    Ottawa
    installed
    I just installed the Sirius FM Modulator and as noted, the antenna connector is the standard type. The install took about 30 minutes and I used the lower glove box method to access the back of the radio. I used heavy duty double sided tape to attach the modulator to the white junction box. FM audio quality is nice and strong and no more interference. Only hassle was moving the junction box out of the way but now I know how to do it, the next time would be simplier.
  9. DocToss
    69
    Cordova, TN
    Did you just pull the connector out by feel? And does the fm modulator require any power source?
  10. kieran
    kieran New Member
    Ottawa
    antenna connector
    The Sirius modulator does not require a power source. I was able locate the connector by feel put it out and plug in the modulator. The connector was on the farest end of the back of the radio, but it was easy to locate.
    The audio quality is like vastly superior to the wirelss modulator.
  11. DocToss
    69
    Cordova, TN
    I did it by feel also, not too hard.
