Radio Doesn't turn on
Discussion in 'Gen 2 Prius Audio and Electronics' started by vovka2007, Dec 7, 2012.
  1. vovka2007
    vovka2007 New Member
    Just got my 06 Prius. The screen shows that Audio Off. The radio doesn't want to turn on. What could be the issue. 06 Prius with nav, Bluetooth, JBL etc. Everything else seem to work except the radio. Fuse perhaps?
  2. vovka2007
    So i swapped the radio unit with my friends car to see if the issue was withing the actual radio unit. Well the sound started working with my friends CD player. Guess my thing is fried. Now I wonder, will a non JBL audio unit work for my car that has a JBL system in it?
  3. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
  4. 69shovlhed
    69shovlhed Surly tree hugger
    2,170
    748
    Delaware
    you either need a new JBL head unit, or bypass the JBL amp. might be able to use the oe wiring to install an aftermarket amp in place of the JBL. if your not good w/ electronics, better get an expert to do that mod so you don't fry something.
