Radio has its own mind
Discussion in 'Gen 3 Prius Audio and Electronics' started by Fernando Varela, Oct 5, 2018.
  1. Fernando Varela
    Fernando Varela New Member
    Phoenix
    Hello everyone. I’m new here and new to the Prius. The wife and I recently bought a 2010 prius cause her new job and due to the commute. The Prius is in really good shape. Now this is an intermittent problem. Not sure where to start but I couldn’t find anything online.
    So the radio works but sometimes when you select the preprogrammed station buttons the radio will turn off. When this happens you can only change the station if you hit the tune or seek button. Again this is intermittent and not a huge deal.
    Along with the radio issue we also have an AC problem. So if we put the AC at max AC it works and blows good air. Then within a couple of minutes the max AC will deselect and the fan speed will go to the middle. If we select max AC right after it works fine but it will do it again a few minutes later. Not sure if this is something that is connected with the radio issue. So as my kids call it it’s a glitch. So want to see if anyone can guide me into what this could possible my. Thanks in advance.
  2. pashko90
    pashko90 Junior Member
    47
    28
    SoCal
    49,504
    welcome!
    sounds like you have some electrical issues which need to be sorted by an expert.
    how many miles on her?
