Radio not working except in Accessory Mode
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by Another, Jan 22, 2025.
Tags:
  1. Another
    Another Senior Member
    1,819
    517
    Naples, Florida
    A friend recently acquired a 2013 Prius Plug in. He tells me that he can’t get the radio to work at all when driving, including no Bluetooth. He recently replaced the 12v battery. He did not test radio before replacing battery. Odd thing is that if he parks the vehicle and shuts it down, the radio “usually” works fine.
    I have not examined it as he is currently far away from me.
    Any ideas what to look at?
    Is there something that needs to be reset after battery replacement?
    52,368
    I doubt this is an internet fix. He’s probably going to need an electronic guru
  3. Another
    1,819
    517
    Naples, Florida
    I agree that long distance diagnostics are not easy, but all I can do at this point until I see car in person in a few weeks.
    Further information I received yesterday. Maybe this will spark some ideas.
    If the car is in Ready mode, radio does not power on.
    If switched to accessory mode, the radio works fine at least until end of travel. Unknown if Bluetooth works at this point.
    But if the car sits for some unspecified time in off mode, the car reverts to non functional radio, unless and utilizes the accessory mode trick is tried.
    Sounds to me like the radio is entering a sleep mode or something.
  4. Paul Gregory
    Paul Gregory Senior Member
    2,227
    592
    Alberta
    2024 Prius Prime
    XSE
    It shouldn't be on with the car stopped. It could be wired live instead of switched.
    BiomedO1 likes this.
  5. BiomedO1
    BiomedO1 Senior Member
    4,108
    2,150
    SacTown, Ca
    Yep, whomever installed that aftermarket head unit, did it wrong!!! See above....
  6. Another
    1,819
    517
    Naples, Florida
    It’s the OEM head unit. Nothing has been modified
  7. BiomedO1
    4,108
    2,150
    SacTown, Ca
    rodents chewing on your wiring harness or someone installing aftermarket equipment? Everything is suppose to shut-off when you turn the car OFF; so obvious someone or something has been messing with it.
    This wouldn't be the first time someone screwed up a car and sold it cheap to some unsuspecting consumer.
    #7 BiomedO1, Jan 23, 2025
  8. Paul Gregory
    2,227
    592
    Alberta
    2024 Prius Prime
    XSE
    Possibly a failure of a control module somewhere.
  9. Another
    1,819
    517
    Naples, Florida
    Seems like a few misunderstandings here.
    First as i said, it works when “switched to accessory mode”, not completely off.
    Second, the history of the car is well known but the prior owner is deceased.
    No aftermarket equipment whatsoever has been installed.
    It appears no one has any suggestions.
    Thanks anyway.
  10. BiomedO1
    4,108
    2,150
    SacTown, Ca
    Sorry, seems all of us are making assumptions and you did ask for suggestions. Please check the title of this thread. :(
    I'm simply suggesting a path forward, I haven't seen the car either and only have what you've typed to go on.
    I'll shut up now!!!
    #10 BiomedO1, Jan 24, 2025
  11. Prodigyplace
    12,665
    11,828
    Central Virginia
    That has not been the case for decades, if not longer. It used to be that 12V lighter sockets were not switched. In most every car now you see the blinking engine immobilizer light. It does not run off of air!
  12. Paul Gregory
    2,227
    592
    Alberta
    2024 Prius Prime
    XSE
    Sometimes it's better to remain silent than to volunteer a mindless guess.
  13. bisco
    52,368
    i doubt this is an internet fix, he's gonna need an electronic guru...
    Prodigyplace likes this.
  14. ChapmanF
    18,521
    D.S. al coda
  15. Another
    1,819
    517
    Naples, Florida
    If I knew how to edit the title, I would, that’s why I clarified it in my further responses
  16. Prodigyplace
    12,665
    11,828
    Central Virginia
  17. Tideland Prius
    16,612
    Another and Prodigyplace like this.
