Radio Operation
Discussion in 'Gen 2 Prius Main Forum' started by berryman, Oct 28, 2004.
  1. berryman
    berryman Junior Member
    55
    Southern California
    Is there some way to operate the radio once the hybrid system is turned off? If so, does it operate off the main battery or the 12V battery?
  2. efusco
    efusco Moderator Emeritus
    19,891
    1,192
    Nixa, MO
    Push the power button once (accessory mode) or twice (IgOn) without pressing the brake pedal and you can operate the radio off of the 12v battery.
  3. Totalshock
    Totalshock New Member
    Toronto
    One warning though... don't do this for too long. At least with my '01, I sucked the 12v dry in less tha half an hour, using it to play the radio while camping with some friends.
    I thought I had left the car turned on, but apparently left it in the accessories mode. That little 12v doesn't last too long if you use it for more than just cranking up the computer and turning the main batteries on.
