Radio Quirk - up/down arrow
Discussion in 'Gen 3 Prius Technical Discussion' started by Codyroo, Nov 21, 2010.
  1. Codyroo
    Codyroo Senior Member
    1,826
    515
    Pleasanton, Ca
    Does this happen with others radios, or did my channel select button get wired in reverse?
    When I press the "down" arrow, the "\/" shaped one, the radio selects the "previous" radio station. So, if I'm in any of the radio settings, in the middle, if I press the "\/" button, I will get the top station programmed. If I'm in the middle and press the "/\" button on the steering wheel, I'll get the bottom radio station.
    The heater controls work like expected. /\ raises the temp, \/ lowers the temp.
    Is mine wonky?
  2. JimN
    JimN Let the games begin!
    7,028
    1,117
    South Jersey
    Nope. It is going to the lower station.
  3. Codyroo
    1,826
    515
    Pleasanton, Ca
    Jim,
    You're saying it works that way for your radio too?
    Because when I "think" of the presets, I think of them like this...
    1.....4
    2.....5
    3.....6
    If I'm on station #2, when pressing the \/ key, I would expect to get #3 (since it is below/lower/further into the screen), but I get #1 instead.
    It doesn't seem "intuitive" to me. But, maybe it's just me.
  4. macman408
    macman408 Electron Guidance Counselor
    1,179
    368
    On the other hand, starting at 2 and pressing down, you should get a lower number, right? So it takes you to 1.
    But I'll definitely grant you that the visual interface is inconsistent.
    Luckily, I don't use the radio at all. Listening to my own music is far superior.
  5. Codyroo
    1,826
    515
    Pleasanton, Ca
    I guess it must be working that way (selecting the lower number position). When I envision the way the radio works, I envision moving the amber "station highlight" bar down using the \/ key, instead of selecting the previous station.
    It is a weird interface.
  6. Teakwood
    Teakwood Member
    491
    73
    New Mexico
    In the words of Woody Guthrie:
    Why? - oh, Why? - oh, Why? - oh, Why?
    B'because - B'because - B'because - B'because
    Goodbye - Goodbye - Goodbye
    :p
