Radio sound erratic?
Discussion in 'Gen 1 Prius Plug-in 2012-2015' started by gray2012pip, Jun 7, 2012.
  1. gray2012pip
    gray2012pip Junior Member
    Orange County, CA
    Has anyone noticed erratic radio sound in their PiP radio? When I drive around Orange County (CA) and listen to the powerful a.m. station KNX, sound seems to switch back and forth between "tinny" and "muffled" (or whatever terms you want to use). It's like I'm going into/out of a tunnel, but it happens frequently, usually once every 1-5 miles. Not sure if I notice it as much on FM, I listen for traffic reports on a.m. a lot and this bugs me. Love the car, anybody else seen this and what did you do about it?
  2. Diddlywop
    Diddlywop New Member
    30
    Irvine, CA
    The radio is switching to and from HD, I believe.
  3. Tracksyde
    Tracksyde Member
    1,429
    762
    So Cal
    I agree with Diddlywop. Its most likely the HD radio "feature" fading in and out depending on your reception. When I listen to KNX, for the most part during my commute, it sounds good with HD radio turned on and working. However, when I drive under a bridge or near electric lines (the big ones along Barranca if you know that area), the HD radio fades out and the sound becomes "muffled" (like what you would normally expect AM radio to sound like).
    You have the option of turning the HD radio off, in which case it wont fade in and out of HD, but it will just sound muffled 100% of the time.
  4. inventor00
    inventor00 Active Member
    1,131
    60
    Phoenix, AZ
    That is what I was told by my OCPrius Club friends also- but yesterday my screen FROZE. Could not push any buttons. Finally hit Audio for the 3rd time and it worked...
    I have the same problem with KNX station...
  5. blmoore
    blmoore Threadfinder
    31
    Pennsylvania
    Thanks - I have the same issue, and didn't realize the HD option.
  6. stu lb
    stu lb Junior Member
    59
    Long Beach
    Thanks for the info--I've had the same problem, and was wondering what was going on. As they say in the computer world, "It's a feature, not a bug!"
  7. bisco
    52,393
    i have it with an hd station here in boston. ireally don't get the hd stuff, it sounds different, not better.
  8. turtlebud
    turtlebud Junior Member
    35
    Pleasanton, CA
    2013 Prius Plug-in
    Sorry to revive a really old thread but we noticed this with our new PiP as well - toggling between muffled and quality. Ideally, we'd want to lock onto only HD, but I'm not sure if that's possible. I'm pretty sure we don't want it to always sound muffled (though it may be a little less annoying than toggling between good and bad quality). A shame because my wife prefers listening to radio (vs. Pandora, etc.) and she's the primary driver.
    Have people found any workaround for the radio?
  9. Chazz8
    Chazz8 Gadget Lover
    744
    235
    61
    Central New York
    Press the HD icon on the audio screen to make the yellow indicator disappear indicating that you temporarily turned off HD for that station. I think there is a setting to turn HD radio off more permanently. From Nav manual page 210; press setup botton, touch "audio", touch "HD Radio Settings", and select "all", "HD only", "analog" to set your radio preference.
    enjoy
    ftl likes this.
  10. SAronian
    SAronian Active Member
    334
    144
    Oakland, CA
    I'm most familiar with HD in the FM band, where it offers greater fidelity as well as range. In Northern California one AM station I listen to KCBS 740 which is HD, however the quality HD seems suspect. When HD is off 740AM sounds like a typical AM station, muffled or limited in frequency range. But when 740AM is in HD mode the sound is very shrill, almost unlistenably so.
  11. CharlesH
    2,797
    1,165
    Roseville, CA
    KCBS is also FM 106.9. According to the HDRadio web site, KCBS has HD on both their 740 AM and their 106.9 FM frequencies.
  12. SAronian
    334
    144
    Oakland, CA
    Thanks, that has been my solution, but I'm curious is something is technically amiss with their AM HD.
  13. SAronian
    334
    144
    Oakland, CA
    As a quick test I tuned KCBS HD 740 AM on my Sony XDR-F1HD tuner at home. The sound was excellent with none of the shrillness present in the cars tuner. So the incompatibility is between the tuner in the Toyota/JBL E7048 and what the station is broadcasting over AM HD.
  14. kenp11
    kenp11 Junior Member
    74
    Orange
    2014 Prius Plug-in
    Yes i am in OC and it sounds like the old radios. Fading in and out. With HD off under bridges gets the sound lower
