Radio wont get power from battery
Discussion in 'Prius c Audio and Electronics' started by Jarrod2027rus, Mar 1, 2024.
  1. Jarrod2027rus
    Jarrod2027rus New Member
    Illinois
    After installing and then uninstalling an after marked radio i no loner ger power from pin d/4(i will try and attach diagram), all fuses look fine and the abs light is now permanently on, any opinions/fixes
  2. Tombukt2
    Tombukt2 Senior Member
    8,909
    1,552
    Durham NC
    Is the battery on this car still back in the back of the vehicle on the right or left side or whatever Make sure all the connections there good I guess I mean you pulling the stereo in and out should have no bearing on all of a sudden not having power on the plus terminal of the harness but you have power on the remote terminal? Yeah that's interesting I guess check to make sure it's not running the ground or something but that should blow the fuse.
  3. Leadfoot J. McCoalroller
    7,133
    6,682
    Pennsylvania
    2018 Prius c
    Test the fuses with a meter, looks can be deceiving.
