Radio won't go bright enough
Discussion in 'Gen 3 Prius Main Forum' started by Stu9, Apr 9, 2025.
  1. Stu9
    Stu9 Junior Member
    84
    Near Mearns
    Yes I have it turned up full to max but in daylight I can't see it at all.
    Is there some kind of back light out.
  2. Mendel Leisk
    40,457
    I've got the same problem, with the speedometer. Driving on wet street hit by bright sun is the worst; you can fugedabout knowing how fast you're going... :rolleyes:
    51,014
    it's certainly possible, 18 years isn't a bad run
  4. Stu9
    Stu9 Junior Member
    84
    Near Mearns
    What's possible ie a back light out. I remember seeing a setting somewhere for day, night, auto but can't find it now.
    It really is bad during the day.
    It is 12 years old not 18.
  5. bisco
    51,014
    sorry, i was looking at your vehicle. anything is possible with these units. do you have a copy of the operating manual? that should spell out the day/night option
  6. Stu9
    Stu9 Junior Member
    84
    Near Mearns
    No manuals but everything's online now but no there is no setting other than brightness and contrast.
  7. Stu9
    Stu9 Junior Member
    84
    Near Mearns
    As I said the brightness is full and you simply can't see the screen during the day, it is hellish.
  8. bisco
    51,014
    sounds like you need a new one. salvage or ebay
  9. Stu9
    Stu9 Junior Member
    84
    Near Mearns
    Could end up getting one a old as this and the same problem.
    Is there a bulb inside it that can be replaced.
  10. Mendel Leisk
    40,457
    There’s probably nothing “wrong” with it; noticed a few days back, driving on wet streets with bright sunlight, no way to see what speed you’re doing. Coming from a second gen Civic Hybrid dash, definitely a downgrade.
  11. bisco
    51,014
    i'm not sure how these lcd screens are lit. or is 'liquid crystal display' self explanatory?
  12. Stu9
    Stu9 Junior Member
    84
    Near Mearns
    Mendel I can see the speed on top etc fine, it is the radio I am taking about, it doesn't need to be sunny just during the day in general you can't see it.
