Raising the Vehicle
Discussion in 'Gen 3 Prius Accessories and Modifications' started by vinnie97, Oct 6, 2010.
  1. vinnie97
    vinnie97 Whatever Works
    1,430
    277
    Somewhere out there
  2. mgb4tim
    mgb4tim Noob
    1,153
    111
    Pittsburgh, PA
  3. vinnie97
    1,430
    277
    Somewhere out there
    A bumpy, gravel-laden, intermittently rocky road with the occasional ravine (and one steep hill!). ;) This would be a peace of mind mod, since I may be moving to such an area soon (about 3-5 miles of such conditions).
  4. andino
    andino Senior Member
    746
    550
    San Jose, CA
    The car isn't that low. I went camping and drove down an area with such conditions and my car is lowered. Just take it slow and you'll be fine. If you're set on raising the car up, I would go with coilovers so that the spring and strut agree on valving and you can adjust the dampening to compensate for the added ride height.
  5. vinnie97
    1,430
    277
    Somewhere out there
    I must have hit a particularly rocky section then, as a panel came loose. :(
    Do you have a link for the items you just suggested?
  6. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    your first link looks ok... i don't really recommend them as i tend to look at the more expensive full packages. i'm worried about it eventually bending your spring.
    have you added a front tower stabilizer bar? (help control the pitch/bouch)
  7. V8Cobrakid
    3,790
    152
  8. vinnie97
    1,430
    277
    Somewhere out there
    They are very shallow, haha, but thanks for the link. I have certainly not done the former (front tower stabilizer bar). I was hoping to hear from someone whose actually done/had a mod done to lift the suspension and could report back with success.
  9. Prius Happy
    Prius Happy New Member
    114
    Irvine, ca
    car isn't made to go off road -_-
  10. vinnie97
    1,430
    277
    Somewhere out there
    It's not off-road, it's an undeveloped road.
  11. cproaudio
    cproaudio Speedlock Overrider
    2,401
    758
    CA
  12. vinnie97
    1,430
    277
    Somewhere out there
    I appreciate that. Those look to be well made. I don't have a lift of my own (I suppose I could jack up the car) and would rather have a pro install them. If there was a matching kit for the front, that would be stupendous (carrying extra weight that would weigh down the back end would not be a regular occurrence).
  13. vinnie97
    1,430
    277
    Somewhere out there
    Truckspring.com personnel informed me that the Firestone spring helpers won't raise the suspension, only keep it from dropping under heavy weight.
    The original products from JCWhitney still may be my best affordable option, though I worry about fitting since they're universal.
