Ran 100 fwy miles with no oil cap
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Terri Salhus, Oct 11, 2021.
Tags:
  1. Terri Salhus
    Terri Salhus Junior Member
    I noticed a rumbling noise when I hit the gas pedal. I look under the hood & notice no oil cap...most of my oil had leaked out, but still shows a little on the dip stick. At first I thought someone ripped my Catalytic converter, since thats popular these days, but now im not sure what to think? It runs, but of course i dont want to drive it again, but i also dont want to walk in blind, especially to the dealer...any suggestions, Would be greatly appreciated?
  2. rjparker
    rjparker Tu Humilde Sirviente
    10,147
    6,305
    Texas Hill Country
    No warning lights came up? I would fill the oil and try it.
  3. PriusCamper
    PriusCamper Senior Member
    12,760
    5,169
    Pacific Northwest, USA
    If you didn't lose all the oil and you've since refilled it the only issue you have is a dirty engine compartment... Make sure you clean it. Show us pics of what it looks like. I've always wondered?
  4. sam spade 2
    sam spade 2 Senior Member
    7,035
    2,802
    2017 Prius c
    First......if there was any oil on the dipstick at all, when wiped off and then re-inserted (engine off of course), then you didn't really lose that much. Fill it and don't worry.
    As for cleaning the engine, that can cause more problems than it solves if you aren't careful.
  5. don_chuwish
    don_chuwish Well Seasoned Member
    823
    190
    Southern Oregon
    But.... where did the oil cap go?
  6. Mendel Leisk
    41,447
    How much? Below the lower mark?
    No oil pressure light, a little showing on dipstick; you could be fine. As others said, top it up and see how it goes.
    I’ve done the same thing btw, with a previous vehicle. No long term problem.
  7. PriusCamper
    12,760
    5,169
    How bad was the mess in the engine compartment? I know someone who had a huge mess with his Toyota truck when he did this, but have never seen how bad the mess is with a Prius?
  8. Mendel Leisk
    41,447
    It was a Honda Accord. Not too much mess. My wife was driving it more than me, and started noticing smell, from the cabin air intake. Never did that again; from then on: put the oil cap in vicinity of hood latch, so it can't close properly, if you were to forget the cap there.
  9. PriusCamper
    12,760
    5,169
    Every time I add oil or do an oil change I always worry if I remembered to put the cap on... Over-active minds can think up problems that don't exist. :)
  10. don_chuwish
    823
    190
    Southern Oregon
    The cap location doesn't help. Recently did the oil change on my 2007 Prius and the cap is way in the back. Then I was checking the oil on my Odyssey and realized that when you put away the hood strut you end up staring right at the oil cap - kinda hard to forget.
  11. Terri Salhus
    No cc warning lights, still, but it sounds like shit...it rumbles low???
  12. bisco
    51,928
    have you filled the oil? replaced the cat?
