Ran out of gas after 472 miles
Discussion in 'Gen 2 Prius Main Forum' started by mini2prius, Feb 28, 2006.
  1. mini2prius
    mini2prius Junior Member
    72
    I've read that the tank shrinks in the winter, but only 472 miles? Given the MPG for the current tank was right at 49 mpg, I would've expected to go a little further. Total gas added to fill up the tank was less than 9.871 gallons according to my gas receipts (still some gas left in the newly purchased gas can.) IIRC, the prius tank is supposedly 11.9 gallons, which gives roughly 2 gallons worth of "shrinkage"? Sheesh. :angry: The last fuel indicator pip, which I thought meant i had a bit over 2 gallons left in the tank (more than 100 miles travel left at avg. MPG) started flashing probably about 30 - 35 miles before I ran out. Guess I'll be paying more attention to this in the future.
  2. mdmikemd
    mdmikemd Member
    436
    Minneapolis
    We've been getting, what I think, is a lot of "Ran Out of Gas" threads. C'mon guys, get gas! The lowest I've ever gotten it to is 2 pips, but I usually fill up at 4. My wife drives the kids around in the car, I don't want to take the chance of them getting stuck somewhere.
  3. daronspicher
    daronspicher Active Member
    1,208
    I'm going to make my best attempt to track the lifetime real mpg (forget the mfd), but somehow the "Biggest baddest single tank" number has no intrigue...
    I did get down to the last square just before filling up last time (I've only had 3 fillups)...
    I thought when I got to the last little block on the gague, it would blink, make noise or tell me something... but.. nope.. nuthin...
    What's the deal on that? Gotta drive another 20 to 50 miles before it blinks, then I have... 20 to 30 miles left?
    Interesting... most vehicles will start yappin at you with 1/8 tank left. Prius has 1/10 left and no warnings or low fuel indication.
  4. john1701a
    john1701a Prius Guru
    12,760
    5,246
    57
    That "ok to push it" mindset is the very reason Toyota made the gauge blink sooner, figuring a non-emergency capacity of 9 gallons would be acceptable.
    The blink means it's time to refill the tank. Don't ignore it... because sometimes you won't actually have as much gas available as you thought.
  5. DaveinOlyWA
    15,140
    611
    South Puget Sound, WA
    2013 Nissan LEAF
    i get pretty good gas mileage but in winter i usually get gas at around 450 miles. last tank i had was alltime winter record and record for fillup quantity. unusual that you could only go 35 miles... i can go max 65 miles when bar blinks. i set trip B when it blinks and i have been using CANVIEW to track "miles to empty" and last bar starts blinking on average about 13%.
    basing your mileage to empty on a full tank (your 472 miles) is a huge mistake. i blogged reasons why. shortfilling your tank takes mileage off the end of the tank, not the begining. to do what you are doing, you need to pay attention to when the first bar disappears. how much sense does that make?
  6. Presto
    Presto Has his homepage set to PC
    1,326
    24
    Vancouver, BC
    The gas guage flashing is a good indicator to get gas. If you decide not to listen to it, you shouldn't complain about running out of gas if it does happen.
  7. V8Cobrakid
    V8Cobrakid Green Handyman
    3,790
    152
    i'm sure you get the " get gas comment by now".. so i'm gonna ask.. do you not fill past the first click? if empty you may have to "burp" the blatter.. fill it up till it click.. rock the car a bit.. and you can usually put more gas in.. If you fill nice and slow, you should be able to fit at least 10 to 11 gallons in when cold (experimented when only 15 degrees out in Colorado)... but you have to take the time.. fill slow (so the bladder can slowly expand) and burp it so you get the air out of the top. You can also fill the tube... so over 12 gallons over all? but it's not recommened since it basically clogs your vapor circulation system-thingy-magigy < you like that huh? lol
    happy driving :)
  8. galaxee
    galaxee mostly benevolent
    9,810
    466
    MD
    you will never get 11.9 gallons in that tank, no matter how long you stand at the gas pump.
    unless your name is Ray Moore.
  9. V8Cobrakid
    3,790
    152
    when the guys did that 106mpg run they put in 12.8..... not saying i ever did it.. but it has been done. It may take a good half hour though ;) lol
  10. DaveinOlyWA
    15,140
    611
    2013 Nissan LEAF
    but neither one did it in the winter time
  11. V8Cobrakid
    3,790
    152
    lol... i know :rolleyes: give a poor guy some hope :lol: ;)
  12. bigdaddy
    bigdaddy Member
    991
    Duluth Georgia
    mini2, where are you located and what was the outdoor temp over the last couple of refills? Do you store the car outside at night? How about during the day, at work?
  13. gschoen
    gschoen Member
    343
    Chicago/Wrigleyville
    2014 Prius Plug-in
    In all my other cars, I've filled up before E since the few times I've run out of gas in my life, it's always cost me hours of time and wasn't worth it.
    After filling the Prius with only 6 gallons I've trained myself to wait until after the flashing PIP. If I'm going to stop for gas, I really like to put in 10 gallons, just to feel I actually added more than fumes.
    Must say the flashing Pip REALLY REALLY bugs me though.. taunting
  14. KTPhil
    KTPhil Active Member
    1,379
    sigh... deja vu all over again.
    :rolleyes:
  15. Thomas Brock
    Thomas Brock New Member
    87
    Am I the only nearly paranoid fella here? Two pips, I get gas...Actually had a blinking pip the other day and nearly wet myself in fear of running out... :blink:
  16. V8Cobrakid
    3,790
    152
    hehe.. amusing :rolleyes: nah.. us conservative tree hugging hippies (had to throw in the stereotypicals) like to live on the edge. lol
    I know i'm never too far away from a gas station, so running out isn't ever really a problem seeing my normal commute is from home to a shopping center where my local gas station is. it's only a 3 mile trip too.
  17. RobertL
    RobertL New Member
    Columbus, Ohio
    Do you by chance live in Northern Virginia? I seen a Prius on the shoulder of Interstate 66 this weekend. Was going to stop but didn't see anybody there.
  18. Rancid13
    Rancid13 Cool Chick with a Black Prius
    2,452
    Los Alamitos, Orange County, CA
    Ditto. On my first non-dealer fill-up I got down to 3 pips before I filled up. My second tank I realized that I was down to 2 and thought, I'll get gas on my way back into work (~10 miles from where I was) before it got down to 1. A few minutes later it was down to 1 pip and I immediately made a beeline for the nearest gas station. I never want to see a flashing pip. I just don't have the desire to push my luck that far. :)
  19. finman
    finman Senior Member
    1,287
    111
    Albany, OR
    2014 Nissan LEAF
    I've actually a new game to play, instead of the how many miles per tank I can get.
    It's called how many 400 mile tanks (350 in winter) can I get for under 20 bucks a fill.
    It's especially fun when the next vehicle over is still going over 40 bucks after you've paid and gone.
    Again, your mileage (cost) may vary.
  20. aaf709
    3,862
    2022 Prius Prime
    Me too. The only time I got a blinking pip was when I was across the street from the gas station I was heading to. :)
