ran out of gas at 397 miles
Discussion in 'Gen 2 Prius Fuel Economy' started by urs70, May 19, 2008.
  1. urs70
    urs70 New Member
    Yesterday I ran out of gas at 397 Miles since the refill. According to the MFD I was getting 41.3 mpg since the refill. Since the manual said the capacity is 11.9 gallaons I thought I would be safe. Also the towing guy said he filled about 1.5 gallons and my subsequent fill up was only 9.4 gallons. Even allowing for some inaccuracy that seems quite less than 11.9.
    In any case that teaches me not to cut it so close the next time. But other than that should I worry about the functioning of the display, the tank or anything else. Anybody else verified the tank capacity (hopefully without getting stranded)?
    As a side note, I love the fact that the hybrid drive let me safely pull over. Never thought about that before.
  2. 9G-man
    9G-man Senior Member
    1,273
    194
    Atlanta, GA
    You know what 9.4 gallons x 41.3 mpg = ? 388 miles .
    Your anticipated range for that tank would have been 388 miles, and you ran out at 397. quite simple and quite accurate.
    My point is, if you didn't pump it into the tank, don't assume it's there.
    Now that you ran out, though, you'll always know how much is in there, because it's no more than what you put in.
    Yeah, I verify my tank capacity everytime I fill up. The capacity is how ever much I pump in, and I always know my anticipated range by multiplying the gallon I pumped by my average MPG since fill up. Never lets me down, I've never run out of gas, I get over 600 mile every tank, and pump little more that 10 gallons each time.
  3. Huntceet
    Huntceet Junior Member
    85
    Chicago area
    2018 Prius
    So how many miles did it go once the last pip started flashing?
  4. pewd
    pewd Clarinet Dude
    331
    Dallas, Texas
    read those other threads.
    the tank has a variable size ; its not fixed , it changes with age, temperature, and some unknown magical factors. its a fuel bladder - it changes, it moves, its alive...
    when you get down to 2 pips, fill that baby up
  5. mingoglia
    mingoglia Member
    846
    Gilbert, AZ
    OMG, I can't believe someone else ran out of gas. I think they should take driver's licenses away from these people. If you can't follow a simple fuel gauge that disappears to one bar and then flashes telling you to fill up how can society expect you to follow the rules of the road? Perhaps you should be locked in a rubber room so you are no longer a danger for yourself and others. Seriously, yeah, this is a bit harsh, but come ON!! A Prius is like any other car. When the gas gauge indicates low, get some fuel. Once again, this is harsh... but the reality is I'm just posting what everyone else is thinking.
  6. ZC1
    ZC1 Junior Prius Owner
    711
    Metro Detroit
    And I did just that today. My FIRST FILLUP!!
    I was armed with a towel just in case the fuel burped, inserted the nozzle fully and set the pump on auto watching it closely.
    The pump clicked off at 7.8 gallons, I waited 10 seconds, removed the nozzle and guess what happened??
    Uh..actually, nothing. Was I ever relieved! :p
    The tank from the dealership lasted 364 miles and I had just entered into 2 pips. I'm sure I could have gone another 50 miles at least. I only spent $30 bucks.
    I'm sticking to Pewd's advice.
    ZC1
  7. bwilson4web
    16,114
    As you've realized, running out of gas in a hybrid gives options not available to ordinary cars. I've done it over two dozen times as part of my gasoline experiments. I just drive to the nearest safe place, put in 1 gallon and then drive to a gas station. Of course my Prius is well beyond any warranty "issues" and I know how to clear the codes.
    My experience is the usable gas is ~11.3 +/- 0.2 gal.
    GOOD LUCK and perhaps we can work on that 41 MPG?
  8. urs70
    urs70 New Member
  9. urs70
    urs70 New Member
    I would love to. I just can't seem to go much over that. Ofcourse I mostly drive distances of less than 5 miles and then stop. I keep the pressure at 38/36. OTOH 41 is still well over 2 times the MPG from my previous car and I don't drive a lot nowadays.
  10. mingoglia
    mingoglia Member
    846
    Gilbert, AZ
  11. urs70
    urs70 New Member
    mingoglia, That's quite gracious of you. I guess I just didn't want to be considered dangerous with all the kind of drivers I see around everyday.
  12. Jimmie84
    Jimmie84 New Member
    1,074
    77
    Minnesnowta
    Also, Just to add that you should never run your tank dry. Mainly because you have a submerged fuel pump and the it relies on gas being in the tank to keep it cool. So, When you run it dry the pump will basically overheat and now you got problems.
  13. Danny Hamilton
    Danny Hamilton Active Member
    926
    94
    Greater Chicagoland Area
    While I agree that you should never run your tank dry, I'd say that based on the photos of the inside of the tank that can be found here:
    http://priuschat.com/forums/prius-technical-discussion/30593-gas-bladder-exposed.html
    The pump is only ever partially submerged, and when you get down to your last gallon or two it doesn't seem to be submerged at all (notice the pickup filter extending out the bottom of and remaining below the level of the pump).
    There are a variety of reasons to avoid running out of fuel, but I'm not terribly concerned about overheating the pump.
