Ran out of gas, check hybrid system light. HELP?
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Brittneymaui, Jan 4, 2016.
  1. Brittneymaui
    Brittneymaui New Member
    Maui, hawaii
    I ran out of gas in my 2011 Prius and immediately all warning lights came on as well as the "check hybrid system" light. After filling the gas I read similar threads on here and trouble shooted the battery. 12v Battery tested good, so now what is the next step? I also did a reset on the 12v battery and that didn't work. I appreciate any help.
    49,479
    welcome! how many gallons did you add? is it starting?
  3. 48mpg
    48mpg Member
    193
    46
    florida
    I
    you need at least 3 gallons in the tank,if you ran the traction battery dead you might have to get it towed to the dealer for a recharge.
    how many bars are showing on the display for the battery?
  4. Brittneymaui
    Maui, hawaii
    The gas gauge now show 4 bars. When I press power the lights all come on and it won't allow me to put it in drive or reverse.
  5. 48mpg
    48mpg Member
    193
    46
    florida
    I
    how about the battery display..it sound like you ran the main battery down
  6. 48mpg
    48mpg Member
    193
    46
    florida
    I
    you might want to try to disconnect the black wire on the 12 volt where it screws into the body and let the car sit for about 5 min's then reconnect it and start as normal..computer might need to be reset.
  7. Brittneymaui
    Maui, hawaii
  8. bisco
    49,479
    looks good, did you add 5 or 6 gallons?
    also, recheck your 12 volt connections, and where the ng attaches to the body.
  9. Brittneymaui
    Maui, hawaii
    Does the above image indicate anything about battery life? I tested the 12v and "reset" it by unplugging and replugging but that didn't work.
  10. Brittneymaui
    Maui, hawaii
    I put in 5 gallons
  11. mrbigh
    3,686
    699
    Long Island, NY
    Important question, you did run out of gas and for how long did you drove in EV mode?
    the Hybrid battery might be depleted....................
  12. bisco
    49,479
    yes, you battery gauge looks perfect. what do you mean by 'unplugging'?
  13. bisco
    49,479
    are you getting the ready light?
  14. Mendel Leisk
    38,720
    Your hybrid battery charge seems ok:
  15. Brittneymaui
    Maui, hawaii
    No ready light.. I rolled about a mile straight downhill last night into my garage when all the indication lights came on.
    The guy from AAA unplugged the 12v battery this morning to see if that would reset the system but it didn't change anything.
  16. bisco
    49,479
    okay, you want to have someone check those connections, and also test your 12 volt again.
  17. Mendel Leisk
    38,720
    Regardless of what the state-of-charge is reading, maybe you upset the system somehow, running electric-only while out-of-gas. That's a very common circumstance. Hopefully a dealership will read the codes, sort it out. It may just need some intervention with their software, and you'll be ok: the charge indicator is a big positive.
    A little late now: but in future, aim for good mpg, not high miles per tank.
  18. Brittneymaui
    Maui, hawaii
    So are you saying that the AAA person didn't do it right? They were here 5 minutes ago and I saw their machine read the 12v as battery good.
  19. Brittneymaui
    Maui, hawaii
    Yes:) I feel like an idiot. If I upset the system how do I make it happy?
  20. Brittneymaui
    Maui, hawaii
    Is there any alternative to having it towed to the dealership (I.e. Bringing the device here?) I live SUPER far from town.
