Ran out of gas --computer locked up
Discussion in 'Prius v Care, Maintenance and Troubleshooting' started by timohilo, May 17, 2012.
  1. timohilo
    timohilo New Member
    Hilo, Hawaii
    2004 Prius ran out of gas and ran out of battery trying to get to gas station. Car sopped with exclamation in triangle and would not turn off . Would go into park. Put gas in but still acted like a frozen pc. Disconnected 12 volt and when 12 volt connected car started and worked normally. Question-- is there any way to reset computer other than cold boot?
  2. cwerdna
    cwerdna Senior Member
    12,544
    2,123
    SF Bay Area, CA
    I've never run my Prius out of gas and I bought mine new in January 06.
    I've never heard of this locking up business either. How many gallons did you put in? I believe you have to put in at least 3 gallons for it to register.
  3. cproaudio
    cproaudio Speedlock Overrider
    2,401
    759
    CA
    Wrong forum. Just be glad that you didn't damage the HV battery pack.
  4. qbee42
    qbee42 My other car is a boat
    18,058
    3,074
    Northern Michigan
    1) Don't run out of gas.
    2) Don't try to drive to a gas station if you ignore #1.
    3) After ignoring #2, a 12V disconnect may be the only way to reset. It's not a standard condition.
    4) Please post in the correct forum.
    Tom
  5. seilerts
    seilerts Battery Curmudgeon
    3,326
    1,512
    38
    Santa Fe, NM
    Running out of gas sets one or more DTCs (P3190, P0A0F). Running the hybrid battery low will set another one, P3000/388. The car will restart with a power cycle on the former, but not the latter. On the latter, the only option is to clear the code with a reader and restart, or do a 12V battery disconnect.
  6. timohilo
    timohilo New Member
    Hilo, Hawaii
    Thanks for help.
  7. hill
    8,183
    Our pleasure . . . . no more close calls . . . right?
    running dry is a tough way to say 'hi' to PC folks . . .but welcome to the group!
