Ran out of gas! Opportunity to assess gas tank capacity
Discussion in 'Gen 2 Prius Main Forum' started by fragglestickcar, Sep 3, 2018.
  1. fragglestickcar
    66
    38
    New York
    So I was on my last pip for an indeterminate distance, and I ran out of gas on the highway. Fortunately the car threw all the lights about 1/4 mile before kaput, and that was enough to pull over to the service road.
    There's been a lot of talk about the bladder issue, how much fuel of the 11.9 total is unusable, and does filling up really get you to the 11.9.
    Well, for better or worse, I endured the empty tank to put these questions to rest, at least for my second-hand 2006 Gen2 with 125k miles, 120k of which were not my own.
    I am happy to report that my tank took a full 12 gallons after the incident, meaning that the car used every last drop before expiring, and that nothing got in the way of a complete fill-up to the nominal capacity.
    Now crossing my fingers I didn't damage the HV battery or fuel pump too badly.
    DLC82SV likes this.
  2. ChapmanF
    15,476
    What makes your experiment sort of irreproducible is that changes of temperature change the elasticity of the bladder, and therefore how much fuel you can put in.
    The answer you got this time was the right answer, this time. :)
    -Chap
    jerrymildred, DLC82SV and srellim234 like this.
  3. wjtracy
    wjtracy Senior Member
    11,321
    3,590
    Northern VA (NoVA)
    12 gals is pretty good, we are lucky to get 7 gals these days from flashing PiP.
    >>What did you usually get before the 12 gals fill from total empty?
    We did have a funny recent thing happen, we were highway driving and all of sudden we went from 3-dots to flashing PiP. Alls I can figure is the gas tank flexed but I do not know.
  4. DMC-5180
    DMC-5180 Active Member
    292
    134
    I ran out once as I exiting the interstate headed to the gas station. I came up a 1/4 mile short but was able to roll into the pumps with battery and gravity (slightly down hill) I nursed it full to the point it wouldn’t take anymore. 11.9 is was I got.
    iPhone X ?
    fragglestickcar likes this.
  5. Fredsimm
    Fredsimm Active Member
    188
    117
    Tupelo MS
    I ran out with 2 pips showing. Now 2 pips = time to fill up.
  6. DLC82SV
    DLC82SV Member
    241
    119
    Oh crap! Not ideal!
  7. fragglestickcar
    66
    38
    New York
    From true empty or from flashing pip? The reason why I ran out in the first place is because I've conditioned myself to believe the flashing pip means "still 50+ miles to go." I've never gone true empty until yesterday. From 30-40 miles after flashing pip, I usually get 9-10.
  8. wjtracy
    11,321
    3,590
    Northern VA (NoVA)
    Sounds like your guess tank is doing well. Our tank is not taking in as much gasoline anymore.
  9. Patrick Wong
    18,200
    6,472
    Maybe the 12V battery is starting to flake out and a cell temporarily shorted, depressing the 12V bus and causing the fuel gauge to reset?
  10. wjtracy
    11,321
    3,590
    Northern VA (NoVA)
    Good thought but 12v is new, maybe something else flakey like combo meter?
    But it was 90F so I thought it could be gaso tank flexing more open.
  11. #1 Toyota salesman
    110
    70
    GSP, SC
    I routinely get 11.6-11.8 in there (I like to live on the edge)
  12. Jenn L
    Jenn L New Member
    Mine is 2008 and since last year from blinking light on, I can only fill the most is 8 gallons, just 2 weeks ago, it got worse. Now I can only fill 4+gallons.
  13. wjtracy
    11,321
    3,590
    Northern VA (NoVA)
    Ours is like that too now...although we get 6 gal in there. I assume the flexible gas tank has lost it's flex, but the tank is not visible so we have to guess. That's why they call it a "guess" tank. It is obviously worse in cold weather.
    Also every couple of months we get a bogus flashing pip suggesting the tank instantly went empty from semi-full status.
    #13 wjtracy, Dec 6, 2018
  14. DMC-5180
    292
    134
    I lose about 1.5 gallons of capacity in winter months due to the bladder losing elasticity.
    iPhone X ?
  15. golfmk681
    golfmk681 Active Member
    262
    105
    los angeles, ca
    I really wish there was a wa to fix the bladder issue. I drive a ton and having 6 to 7 gallons is annoying. I fill up every 2-3 days. Makes me long for an electric car. Lol
  16. bisco
    49,393
    trade up to gen3!(y)
    fuzzy1 and Mendel Leisk like this.
  17. Skibob
    Skibob Senior Member
    2,912
    1,496
    Northern California
    Japanese models did not have a bladder. If you change out could you do a write up here?
  18. Mendel Leisk
    38,652
    I think European too, no bladder tank? Googled threads on this, and concensus seems to be that to replace the tank with bladder-free is too expensive, too much hassle. Frustrating situation...
  19. golfmk681
    262
    105
    los angeles, ca
    Yes if it was a super simple mod, I’d do it but dropping the tanks, etc means I’d have to pay someone. And this being a 13 yr old car, I don’t know if this car has 1 year left or 10 years. It’s all hard to tell really.
  20. Skibob
    2,912
    1,496
    Northern California
    You live in LA it doesn’t get that cold. Do you fill up in the morning or afternoon? Has to be warm enough most afternoons in LA to not have a problem.
