Ran out of gas - P0420 code
Discussion in 'Gen 2 Prius Main Forum' started by mountain_matt, Nov 19, 2019.
  1. mountain_matt
    mountain_matt New Member
    Ran out of gas, check engine light is on with P0420 code.
    Could running out of gas cause CAT failure, or is more likely to be the 02 sensors?
    Photo of home diagnostic posted.
    Thanks for your help!
    -Matt
  2. SFO
    SFO Senior Member
    5,297
    4,237
    Northern California
    How many miles do you have on the vehicle?
    49,568
    welcome! did you get her restarted?
  4. PriusCamper
    PriusCamper Senior Member
    11,119
    4,526
    Pacific Northwest, USA
    Sometimes it takes as much as three gallons of gas to get things working normally again... Also do the codes come back right away after you clear 'em? Or does it take a while?
  5. MilkyWay
    MilkyWay Active Member
    819
    358
    23
    MI
    That will happen to every Prius that runs out of gas. Happened to me. Add gas, clear code, it will not come back.
    SFO likes this.
