random convo starter - what's the most frequent cause of the p0171/2 codes?
Discussion in 'Generation 1 Prius Discussion' started by ronlewis, Sep 13, 2024.
  1. ronlewis
    ronlewis Active Member
    977
    196
    texas
    2001 Prius
    It can be so many things. The service manual doesn't suggest any one over the others, and I can go through all of them one at a time, but maybe everyone's experience here (all three of you) will suggest one to start with. WTH?
    Mine drives fine on the highway. Noticed a slight shudder at idle and found the pending 0171 code.
  2. ChapmanF
    17,855
    Trick question? P0171 and P0172 are opposite problems.
  3. ronlewis
    977
    196
    texas
    2001 Prius
    I understand, but maybe the opposite of someone's frequent cause of a 71 is the cause of a 72. IDK. It's just a random survey. I don't think fuel pumps are a common problem, for example, but maybe everyone tells me they are and I start with the pita fuel pressure test versus, say, cleaning the throttle body. IDK.
  4. ChapmanF
    17,855
    I'm not sure I could think of how a dirty throttle body would be implicated in either one. Only thing more tedious than checking lots of things listed as trouble areas might be also checking things that aren't. :)
    You write that the manual "doesn't suggest any one over the others" ... but it does give a troubleshooting procedure with steps numbered 1 through 11. How Toyota picks the order of their troubleshooting steps may be kind of mysterious, but probably reflects some balance of what they've found the most common causes to be, with which checks are more or less of a pita.
  5. ronlewis
    977
    196
    texas
    2001 Prius
    All true, and understood. Let me see what the FB groups say.
  6. TMR-JWAP
    TMR-JWAP Senior Member
    6,404
    6,088
    Columbia, SC
    I would say on a Gen 1 and Gen 2, a dirty MAF sensor is a common cause. I've been fortunate enough that both times I've had a P0171 (2 different Gen 2s) each has been resolved by cleaning the MAF sensor.
    ronlewis likes this.
  7. Trombone
    Trombone Active Member
    313
    109
    Allentown, Pennsylvania
    2002 Prius
    This. See also Patrick Wong's relevant post here: MAF Sensor, What is it, Where is it | PriusChat
  8. ronlewis
    977
    196
    texas
    2001 Prius
    I sprayed my sensor down today actually, although I didn't start it afterwards - have the battery charging. Will do that tomorrow. However, I think I did that when it first acted up a month or so ago - the spray was in the front seat of the car. Haven't looked at it since then. probably should swap over a known-good MAF sensor.
    Someone else suggested the PCV hoses - that was good, the kind of thing one wouldn't typically think of first as a failure point, but in fact, I've pulled mine off the throttle body many times, and wouldn't be surprised if there as a crack in the hose somewhere. Looks like a PITA to inspect them however. On this car, the one towards the front of the car has a lightweight wire clamp holding it on the throttle body, while the one on the back side doesn't have a clamp. Is that right? The clamp doesn't look strong enough to matter.
    How can I check whether they have any cracks/leaks without taking them off the engine? Would plugging the outlet at the throttle body or on the hose itself have a noticeable affect? It does stumble a little at idle, for sure when cold. Drives at speed without a problem.
    thx
