Random Shut Down during MID clock time change
Discussion in 'Prime Main Forum (2017-2022)' started by mrchowmein, Nov 1, 2020.
  1. mrchowmein
    mrchowmein Member
    73
    56
    San Francisco, California
    2020 Prius Prime
    So, i was sitting in the driveway with the prime plugged in. I had the car on but not in ready mode to run the heater while I cleaned the interior of my car windows. I then proceeded to change the clock settings for BOTH clocks. I found that aspect annoying since they operate independently and does not auto update even with the GPS, but that's a separate rant. When I changed the time via the MID. The moment i updated the hour and pressed back on the steering wheel, the car shut off. I found that kind of odd. I tried to reproduced this, but I was unable to. Any clue, this is a serious bug if the car shuts off during a time change to the clock.
    I've had the 2020 Prius Prime for about a month and logged in 2,000 miles. First bug I've noticed was a random reboot the infotainment screen. I hope Toyota will release more software updates to address these issues as this car is 3 years in and is still exhibiting reboots.
  2. Trollbait
    12,676
    If you aren't in Ready, the car might auto shut off to keep the 12v battery from draining.
    FuelMiser likes this.
  3. mrchowmein
    mrchowmein Member
    73
    56
    2020 Prius Prime
    the car was on for no more than 3 mins before the shut off. like I said, it shut off right when I changed the clock. this is like some Y2k sh*t. jk
  4. schja01
    schja01 Senior Member
    1,844
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    What @trollbait said. The car is protecting its anemic 12 volt battery.
  5. Trollbait
    12,676
    Coincidence does mean causation. You weren't able to get it to happen again.
    If heating can actually run without being Ready, it will be a heavy load on the 12v battery. I thought the heat pump ran off the traction battery.
  6. mrchowmein
    mrchowmein Member
    73
    56
    2020 Prius Prime
    I just had the car on but not in ready for 10 mins with the heater running. The car didn't shut itself off within 3 mins like earlier today. When the heater was on, the estimated EV range dropped. So the heater should be running off the traction battery and not the 12v.
    #6 mrchowmein, Nov 1, 2020
  7. schja01
    1,844
    1,226
    Chicagoland
    2024 Prius
    Limited AWD-e
    The heat pump is definitely a high voltage device.
  8. m8547
    m8547 Senior Member
    950
    628
    Colorado
    2018 Prius Prime
    The estimated range logic is useless. It drops a fixed amount whether the heater, AC, or just the fan is on. It probably drops with the car is in "ignition on" mode even though the compressor isn't running. The fan runs off the 12V battery.
    jerrymildred likes this.
  9. jerrymildred
    jerrymildred Senior Member
    11,517
    14,157
    Tampa, FL
    I'm only slightly surprised the estimated range dropped. When the car is not in ready mode, the traction battery is physically disconnected from the car. That means only fans can run, not the compressor, which is high voltage. My guess is that the estimated range dropped because the car said, "Hey, I'm gonna have to use the traction battery to recharge the aux battery that this guy is using up with the blower fan and the dash lights and the computers." I'm 99.9999% sure that the actual state of charge did not change.
    When you mess with stuff like that, put it in ready so you don't drain the 12V. IGN and ON really server no purpose on a Prime except to drain the 12V if you have any EV range available.
