Range Display
Discussion in 'Prius v Main Forum' started by alexl, Apr 17, 2012.
  1. alexl
    alexl New Member
    canada
    After refuelling the range display on the dash board shows me still 500km, and does not show me the maximum range, for example 730km.
    This is the second time when I have this problem. I have already 4500km which my new PriusV
    Any ideas?
  2. Paradox
    29,110
    8,589
    201
    2014 Prius v wagon
    How much fuel are you putting? I work in gallons and if around 2 gallons (give or take) is added it will not register as actually adding any fuel. You have to basically add a decent amount of fuel to see a change.
    Btw, the v in your Prius v is lowercase, not upper case. It can cause confusion making it upper case since the Prius lift back for 2010 used roman numerals for packages.
