range for new Prius Prime?
Discussion in 'Gen 5 Prius Main Forum' started by kojack, Mar 24, 2023.
  1. kojack
    kojack Junior Member
    32
    22
    grand falls-windsor, NL
    I have been looking at the new prime since we never purchased the last gen. I am now glad I waited. The new one looks to be killer.
    What's the total range on the prime for both battery and petrol combined? Will it be better than the current prime?
    49,488
    battery is supposed to be about 50% bigger = about 37 miles epa.
    forget the gas tank size, but you should get around 5-600 miles range.
    a lot has changed in the gen 5 prime, some good, some bad. you should really read all the threads, there's a lot of good info, but a lot we still don't know yet.
    kojack and mikey_t like this.
  3. Nntw
    Nntw Active Member
    396
    244
    Toronto
    2023 Prius Prime
    49,488
    unfortunately, japanese specs don't translate well to north american
  5. Trollbait
    11,560
    Japan WLTP gives better results than EPA.
  6. Nntw
    Nntw Active Member
    396
    244
    Toronto
    2023 Prius Prime
    Can we base anything on the ‘% improvement’ comments?
  7. bisco
    49,488
    earlier on, people were translating that to 25 miles x 1.5 = 37.5 miles.
    since most get more than the epa 25 in gen 4 outside of winter, it is hopeful to see 40-50 miles, although the 17 and 19 wheels will kill some of that
  8. Tom_06
    Tom_06 Active Member
    609
    141
    Newark, Delaware, USA
    I thought the OP was asking about maximum range, gas + electric. While electric is maybe 12.5 miles more, the 2023 manual says the gas tank is only 10.6 gallons. My 2017 manual says 11.4 gallons but I seem to remember most of the other literature when I bought it was saying 11.2? If the tank has dropped by 0.8 (or 0.6) gallons and I generally get 50 to 60 mpg with my 2017 it seems like the 2023 total range will drop by something like 27.5 miles.
    Overall an insignificant difference to most people.
    kojack, pakitt and bisco like this.
  9. bisco
    49,488
    what is your average range?
  10. Nntw
    Nntw Active Member
    396
    244
    Toronto
    2023 Prius Prime
    I thought there were #s on the Montreal and toronto auto show car window stickers
  11. Trollbait
    11,560
    Manufacturers do list a range somewhere that is listed tank volume times combined fuel economy rating. How full you can get the tank also falls under YMMV.
    On trips, most people will want to take break before a Prius tank nears empty. Some want to know the range to gauge how often they'll be stopping at the gas station with daily driving. With a PHEV, that can be months with even a tiny tank.
    mikey_t and pakitt like this.
  12. Nntw
    Nntw Active Member
    396
    244
    Toronto
    2023 Prius Prime
    Car and driver also says about 40 miles on battery only.
    2023 Toyota Prius Prime: What We Know So Far
  13. Trollbait
    11,560
    I think you can get an estimate of 40 miles from the EU WLTP results.
    Did Toyota under report the EV range in Europe of the old model to the degree they did in the US?
  14. bisco
    49,488
    when you say under report, do you mean they posted less than the epa test?
  15. Trollbait
    11,560
    Yes. After the changes to the test for what gets reported on the window sticker, Toyota appeared to choose to post a lower value for the Prius. Which translates to a lower official range for the Prime. Don't know if the practice was the same with Toyota EU.
  16. Gokhan
    Gokhan Senior Member
    4,655
    1,866
    Paramount CA
    Gen 5 Prius HEV (43-L (11.4-gal) fuel tank) and Prius Prime PHEV (40-L (10.6-gal) fuel tank) have about the same combined range or perhaps the HEV has a slightly longer range. BEV range on the PHEV is 44 miles (17" wheels) or 36 miles (19" wheels).
    Gen 4 Prius Prime PHEV (43-L (11.4-gal) fuel tank) with its 25-mile BEV range is the unbeatable king of range and fuel efficiency. I get about a 70-mpg actual fuel economy in HEV driving and a 35-mile range in BEV driving. My combined range on my Gen 4 Prius Prime PHEV is about 850 miles (1,400 kilometers).
  17. bisco
    49,488
    that seems crazy, how does that help toyota?
  18. Salamander_King
    Salamander_King Senior Member
    10,975
    8,867
    New England
    Not the new Prime...
    I am getting 85 miles EV range on a single charge from the Escape PHEV now.
    kojack, mikey_t and Gokhan like this.
  19. Gokhan
    4,655
    1,866
    Paramount CA
    That must be downhill driving. I haven't seen 8 mi/kWh even in summertime 25-mph driving on a Prius Prime or Model 3.
  20. Salamander_King
    10,975
    8,867
    New England
    I am sure there are some downhills mixed. That number is the current lifetime EV efficiency on our 4-month-old Escape PHEV with 2480.6 miles on ODO. ;)
    mikey_t, bisco and Gokhan like this.
