Rant: HID Connector and Ballast
Discussion in 'Gen 2 Prius Main Forum' started by Shin Ra, Mar 18, 2023.
  1. Shin Ra
    Shin Ra Junior Member
    Los Angeles, California
    Four Touring
    So a rock destroyed my fender and headlight on my passenger side the other week and i finally got my new headlight and went to move everything over when i noticed that the HID connector snakes through the headlight, but there was no connector on the ballast. Sitting there thinking how in the world did they get this through and then did some google searches and youtube and finally decided to just cut it and solder it together. Whoever designed this and decided it wasn't important for the connector to be plug and play with the ballast needs to be shot...
    Also broke every tab on my fender so had to order some parts to finish that as well.
  2. Tombukt2
    Tombukt2 Senior Member
    12,206
    2,152
    Durham NC
    I removed my HIDs for halogen units with LEDs mounted and I thought I had both left and right here those things snake out but doesn't matter now you fixed it.
  3. Shin Ra
    Four Touring
    I ended up finding another youtube that showed the person removing the headlight adjuster and prying up the plastic a little bit to get the connector out so i guess thats another option but a plug at the end of the silver covered wiring would have been ideal...
