Rattle at medium throttle
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by Benjamin Foss, May 30, 2021.
  1. Benjamin Foss
    Benjamin Foss New Member
    Maine
    A couple months back I bought a 2013 Prius with 180k. It has a new head gasket, valve seals, water pump, thermostat, and the EGR cooler was cleaned 10k miles ago. It's been driving fine and I averaged 57mpg for my last tank of hilly highway driving across PA, which seems pretty ideal. In the last two weeks I started to notice a very faint rattle. It appears between 45-60 mph, only after the car is fully warmed up, and only at mid throttle. (specifically when the HSI is about 1/2 way through the ECO area) It instantly disappears when I change the throttle position, never appears when the HSI is in the power bar, and the engine sounds fine at idle.
    I would describe the rattle as similar to top end tick or a timing chain guide sound, definitely not a knock. I can't always get it to happen. It is not the hood prop or the coolant return hose mount next to the passenger side headlight, but it originates in that area of the engine compartment.
    The oil level is full, and I did an early oil change after I first heard this sound but it didn't solve it.
    Any ideas or similar experience? It could be a preignition issue, but I'm not sure exactly what that sounds like or if it would be so intermittent. It's happened across three tanks of gas from different stations so bad gas is out. Thanks for any input you can provide!
  2. Grit
    Grit Senior Member
    6,147
    4,057
    Wilkes Land
    how did you verify that all those service were performed? Sounds like intake manifold cleaning is due.
  3. Benjamin Foss
    Maine
    I have receipts for parts for the work that the previous owner did, and I did the thermostat housing. No coolant loss or temp issues since the gasket replacement.
    Replacing the PCV valve and adding an oil catch can have been on my list of things to do and I agree that wouldn't be a bad idea, but I find it hard to imagine it would clog up or fill with oil to the point of being a problem so soon and I wouldn't expect an intermittent rattle to be the symptom.
    I should add that it doesn't use a significant amount of oil either, about 1/2 quart in a 4000 mile interval.
  4. Mendel Leisk
    38,709
    Our 2010 has had a buzz at mid throttle, off-and-on, since new. Seems very similar to what you describe. There’s been a few threads here on it, one mentioned a coolant hose bracket just behind passenger side headlight as being the culprit. I’ve tried tightening that, but no change. Anyway, maybe benign.
    EGR cleaning is good, but at 180k miles, a little late in the day: might be the (head gasket) damage is done. And as mentioned by @Grit : how well and completely was this cleaning? It can all be for naught, say if intake manifold EGR passages are missed.
    DIY is the way to go.
  5. Team_Geek
    Team_Geek Member
    62
    30
    MN
    Not quite sure if it is the same as you but I’ve had a few of the exhaust heat shields rust off enough to rattle at certain engine speeds.
    If you can jack the car up and get underneath you can grab the heat shields and give them a wiggle. If they move that could be the problem.
