rattle from driver side dash
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by scottwyden, Sep 30, 2009.
  1. scottwyden
    scottwyden new jersey photographer
    342
    New Jersey
    I'm getting a rattle from here and it slowly getting worse. Started out just over bumps now it is rattling even when the gas kicks in when hitting getting on a highway. Ideas?
  2. quantumslip
    quantumslip Member
    149
    Sugar Land, TX
    wow, i'm not the only one! for me it only happens in certain speeds and road conditions; can't consistently reproduce it. it's soft but noticeable. if i lightly pound on the area above the vent then i can hear a rattle. when i go in for my first oil change i plan to ask the dealer to take a look at it.
  3. Frankblack0503
    Frankblack0503 New Member
    64
    Belgium
    I can't help you with the rattle but my GENIII is also rattling at several places (from dash 2 doors...) What i can't understand is that toyota produces such an innovative car and can't manage to make it 'rattle-free' inside...
    Don't these japanese guys do several severe tests on this before launching this things ???
    Nice car but it's interior sounds make me crazy !
    Only thing i can do at the moment is put the volume on 30 so i don't hear all those things :-/
  4. scottwyden
    342
    New Jersey
    When I hit the area it rattles as well!
  5. dmvp
    dmvp Member
    364
    Outskirts of Chicago
    Please check the prop rod under the hood. That has been the culprit for many rattles!
  6. scottwyden
    342
    New Jersey
    I'll check it this morning!
  7. CaptPJB
    CaptPJB New Member
    Just adding to the list I have it in my Prius IV I was kind of thinking it was the latch mechanism of one of the glove boxes but have not verified that. I need to get the wife to drive while I check it out, problem is she is not keen to drive my "Starship"
  8. scottwyden
    342
    New Jersey
    Not the hood rod. It is safe and snug
    The glove box latch is a good theory but the rattle I'm getting is coming from the driver side
  9. quantumslip
    quantumslip Member
    149
    Sugar Land, TX
    just called to get an appointment this monday morning. i will let you know results afterwards!
  10. springfield
    springfield New Member
    30
    Springfield, VA
  11. blueumbrella
    blueumbrella Member of Prius Regeneration
    294
    33
    Seattle
    I have a similar rattle which occurs more often when the temperature drops. At times it occurs on both sides. I am anxious to hear what you find. Please have your dealer take photos.
  12. quantumslip
    quantumslip Member
    149
    Sugar Land, TX
    the problem went away by the time i went to the dealer, which was frustrating; it does come and go. he did notice that my hood was making some noise; a part of it was loose (the hinge on the left side? not sure what it's called), and after tightening it went away.
    hmm blueumbrella, it's only starting to get colder down here in Texas, but it is still fairly warm. I guess I'll see what happens in November/December.
  13. Fussion101
    Fussion101 Junior Member
    81
    NYC
    Are there gaps around the black border and the side pillar panel or is the panel pressed against the small glass/black border there?
  14. scottwyden
    342
    New Jersey
    No gaps at all.. it's definitely from the dashboard as well
  15. scottwyden
    342
    New Jersey
    My Prius was in for its first service this weekend. For the dash they "put felt under the plastic"
    When I drive I no longer hear the rattle but if I tap it to reproduce the problem I can still hear it. Odd. Hopefully it doesn't come back
  16. Frankblack0503
    64
    Belgium
    Scott,
    can you describe where they put the felt ?
    What did they have to remove ?
    Maybe this can be helpfull for indicating towards my dealer.
    Thanks !
  17. scottwyden
    342
    New Jersey
    driver side dash.. near vent as seen in the photo
    except they put a nick in the plastic which I will be complaining about
  18. mastercut
    mastercut New Member
    italy
    same problem here in Euro version , i noticed that u cn hear the sound if u tap on the dashbord but if u push the dash in the front direct and u tap the sounds disappear.
    I will remove all dashbord next week
  19. itssunnyv
    itssunnyv New Member
    33
    Studio City, CA
    Great Thread everyone! Thanks for the helpful info. I'm making a list of all the rattles I currently am hearing. I'm pretty sure I can hold off until my first check-up, but if things get worse I may bring it in. Some rattles are definitely forgivable since they occur only under certain conditions, but the driver side dash rattle seems a little more regular.
  20. bisco
    48,942
    sorry to hear the eleven is still a rattletrap.
