Rattle on ICE kick-in (low RPM)
Discussion in 'Gen 3 Prius Care, Maintenance & Troubleshooting' started by yak76, Oct 3, 2021.
  1. yak76
    yak76 Junior Member
    new england
    My 2010 prius has started making a metallic rattle while driving, It only occurs when ICE starts or stops and goes away other times.Typically low RPM. You can hear it in the cabin. I can almost have it come on constantly when the Hybrid system indicator is past the middle bar and I keep it there.
    I crawled under today and checked the heat shields starting from the front to back. But all seemed to be firm with no screws loose or missing - nothing seemed out of place - the shield under the cat converter is held on by plastic rivet like things but that was also not that lose. While under in front I reached in to check the heat shield in the engine compartment where the exhaust joins the engine. That was also firm.
    I have about 150k on the odometer and changed the spark plugs and the inverter and engine coolant last year.
    I'm really out of ideas on what could be doing this. Any thoughts?
  2. JC91006
    16,937
    8,647
    Do you have a shield to protect the CAT from getting stolen? If you have one, that's what is rattling.
    52,877
    does it happen at cold start up? have you cleaned the egr circuit?
  4. Mendel Leisk
    42,361
    I think we need a third-gen-with-rattle triage questionare…
    bisco and dig4dirt like this.
  5. meeder
    meeder Active Member
    239
    163
    Doesburg, The Netherlands
    Can't this be the cam phaser?
  6. xliderider
    xliderider Senior Member
    8,140
    3,280
    Honolulu, HI
    Did the rattle start after some work was done on the Prius?
    I had a rattle/tapping sound that was from a bolt that I forgot to tighten on the air intake hose near the passenger side headlight. Once properly tightened down, the rattle stopped.
  7. yak76
    yak76 Junior Member
    new england
    I don’t have a theft proof shield for the cat. Also the EGR circuit has not been cleaned, although this doesn’t sound like the problem. @xliderider we had loosened that bolt while changing the bulb recently, but I tightened and rechecked, and it is not that.
    I attach a file I recorded on my phone and the noise kicks in at 6 seconds or so - sorry not the best quality
  8. bisco
    52,877
    'the shield under the cat converter held on with plastic things is NOT THAT LOOSE'?
  9. yak76
    yak76 Junior Member
    new england
    Well, I did an experiment while I was under- I tied that shield with 2 separate zip ties extending in different directions. So it stopped moving. Still got the rattle, so I ruled it out.
  10. tankyuong
    tankyuong Senior Member
    1,555
    662
    Central MO
    Sounds like the death rattle
  11. yak76
    yak76 Junior Member
    new england
    For serious??!
  12. Mendel Leisk
    42,361
    The recording didn’t sound like hydrolock (coolant getting into cylinder due to leaking head gasket) to me, but considering the miles, I’d get on the EGR cleaning. More info in my signature.
