Rattle Snake or Drum Roll
Discussion in 'Gen 2 Prius Main Forum' started by Rosss, Aug 30, 2008.
  1. Rosss
    Rosss New Member
    Scotland
    Hi People,
    Looking for some assistance to see if I have a fault or not. I have a 2008 Spirit, 4 weeks old. Since delivery I have what sounds like a drum roll or rattle snake chatter from the left hand side of the engine. It seems to occur most when I brake or after braking as I pull away, is this 'standard' or do I have a fault, its like a relay chattering.
    I have ignored it up to now as I assumed it was a normal noise as the car does emit some unusual noises compared to non prius vehicles.
    Hope its 'standard' as I do not want to put it into a garage, when purchasing local dealer did not instill me with confidence, oil change, yes anything more, no.
    Any info. would be appreacited.
    P.S. Anyone recommend a dealer in Scotland ?
  2. NaptownPrius
    NaptownPrius Getting Greener....
    271
    Napolis, Merlin
    That is normal.
  3. Patrick Wong
    18,200
    6,480
    This is normal, the sound comes from the brake pressure accumulator pump. The Prius brake system has this pump in lieu of a normal car's power brake booster that depends upon gasoline engine vacuum.
  4. Rosss
    Rosss New Member
    Scotland
    Cheers guys, just what I was hoping to here !
  5. JimN
    JimN Let the games begin!
    7,028
    1,116
    South Jersey
    The rattlesnake under the bonnet is Toyota's solution to the rodents in the air cleaner.:cool:
